so i connected to the bike with the tuneecu program i was on the test tab and i was running all the test like fuel pump fan ect... then i went to the map edit tab and i click on read map after it was done i click on Edit then export table. then i disconnected the bike and now the bike will not turn on... i turn the key and the kill switch to on but nothing... and now it will not connect to the tuneecu... how do i fix this plz help!
Did you drain your battery? Test that with a multimeter.
#3 |
If you pulled the fuses for the lights, you have to plug them back in for the bike to start also
#4 |
SMH shit i didnt unplug the headlights... it was only on for about 10-15min.... u think i might have drained the bettery?
#5 |
Sounds like you might have drained it.
It is recommended to pull the fuse for the headlights, and to place the bike on a tender while using TuneECU.
#6 |
The battery will drain pretty quick. I didn't pull the fuse but did have battery charger. Didn't kill it but not enough juice to start it. Had to let it charge up before resetting the TPS.
One more detail, I always click "disconnect" on the software before physically unplugging the cable. Not sure if you did that, but I think I read if connection is lost during communication it can cause some troubles. |
#7 |
so i left it alone for a while then decided to try and juice it up with the car... i let that run for a bit... and then i tried it again and it worked so i guess it really was the battery... tnx for ur guys help
