Am I missing a spring? - Triumph675.Net Forums
post #1 of 11 Old 11-08-12, 22:52 Thread Starter
Rink675
Rink675's Avatar
I am stripping the bike down and cleaning everything/ maintenance to make sure the bike is 100% for next race season.
I can't seem to recall if there was a spring here in the pic or not....I would imagine that their has to be because otherwise the throttle body blades would not be aligned. Or does one of the throttle cables of the two pull a little earlier to make sure they are matched up?
I know before I took the throttle bodies off they were all aligned when I twisted the throttle. I just want to make sure if I did lose a spring that I get it replaced.
2007 Triumph 675 Race Bike
Rink675 is offline
post #2 of 11 Old 11-09-12, 00:07
MacBandit is offline
post #3 of 11 Old 11-09-12, 00:23 Thread Starter
Rink675
Rink675's Avatar
yes..
Well I doubt I will come across it but maybe I will get lucky lol
Rink675 is offline
post #4 of 11 Old 11-09-12, 00:27
I've seen those missing from the factory on several bikes (not just Triumph).
post #5 of 11 Old 11-09-12, 00:44 Thread Starter
Rink675
Rink675's Avatar
Interesting.....well it must have been there before I lost it because the blades were all in sync before I started taking them off. Good thing I have 7 months until race season hahaha.
Rink675 is offline
post #6 of 11 Old 11-09-12, 06:35
!!675R!!
!!675R!!'s Avatar
What does the second (missing) spring do?
2013 Triumph Daytona 675R
!!675R!! is offline
post #7 of 11 Old 11-09-12, 11:30
The second spring holds the linkage together. The first spring holds tension on the throttle synch screw so it doesn't move or vibrate out.
post #8 of 11 Old 11-09-12, 11:36
!!675R!!
!!675R!!'s Avatar
Is this the only one or are there more? Like one in between each intake on the throttle body?
!!675R!! is offline
post #9 of 11 Old 11-09-12, 11:40 Thread Starter
Rink675
Rink675's Avatar
No only two, the first linkage controls the first two throttle bodies together and the second linkage is for the 3rd throttle body.
Rink675 is offline
post #10 of 11 Old 11-09-12, 15:56
miky92
miky92's Avatar
Send a message via MSN to miky92 Send a message via Skype™ to miky92
i think it help the other spring to keep the bolt static and avoid his rotation,
it's the bolt that manage the throttle alignment, if it rotate because of vibrations or so, it's a problem...
you do better to get a new spring and check throttle adjustment with tuneECU
edit: damn, i was too slowy...
miky92 is offline
