Getting a RSR triple clamp... What's the stock offset on 675r? - Triumph675.Net Forums
Old 11-08-12, 00:00   #1
Daytona.Scott
Daytona.Scott's Avatar
Default Getting a RSR triple clamp... What's the stock offset on 675r?
So I ended up ordering RSR's triple clamp with 32mm offset. I have talked to them on the phone and they told me that the stock 675r runs 37.5mm Is that a correct number? (I think it's different from older models... triple clamp position itself is different)
When I told them that I ride on NJMP they suggested 30mm, which is the only other size they make... Interestingly enough you can't go less than 30mm without running into the radiator
On the side note, I also got a linear rear linkage and getting my rear suspension re-valved... Tankslapper on fast sweeping left hander before the bridge on Thunderbolt was no fun...
Old 11-08-12, 05:30   #2
dubguy85
I believe stock is 35mm. 26mm is the std that people buy when getting the attack triples. I wasn't aware it hit the radiator though.. I'll need someone else to confirm that.. Good call on the link.. I'll be ordering one soon, but a different company will be making a cheaper option soon. Ask tj at riders this same question about the triples though.. He'll know
Old 11-08-12, 08:28   #3
TonyNyc
TonyNyc's Avatar
I ride and race mostly at NJMP too. I have the white 675 with 2 offset red stripes and am from NYC. Maybe we have met?
I am looking to do the triples and the link this winter.
Keep seeing posts up some 'secret' triples that are coming out and this is the first I am hearing about the link. Very interested.
Need to be sub 1:30 at TBolt next season.
Tks,
Tony
Old 11-08-12, 09:54   #4
We used 26mm on our BMW however on the Triumph 28mm is the number that has worked best for us. We were given this number independently by two different suspension "guru's" in the AMA paddock. One carries a very large Thermos and the other stripped the bike down and measured geometry with and without springs. After he ran the numbers he told us to start with 28mm.
We had no issues with the radiator at a 28mm offset, however if you do run back to 25mm things get VERY close.
Old 11-08-12, 09:56   #5
dubguy85
Ahh 28.. my bad.. that's what I meant..
Old 11-08-12, 11:19   #6
Daytona.Scott
So I am pretty sure pre2009 daytonas have different triple. Older daytonas had front chatter problem that, hence people running triple flush with forks (my friend has that setup on 675... you should be able to find this issue/ fix all over the web)
Also I want to mention that rsr's triple is exclusive to r model. Ronnie at rsr told me that their triple is more "flexible" than attack. They ran attack triple themselves and had trouble with front end feels (attack triple is solid and big chunk of metal)
Also for the rear linkage, you would need revalving and respring to accommodate new linear travel.
On the other note, do any of you guys know whether or not front spring is linear or progressive for 675r? I could not find any information on that
Sent from my Galaxy Nexus using Motorcycle.com Free App
Old 11-08-12, 11:21   #7
Daytona.Scott
Tks,
Tony
We may have :) again there are abouta dozen of 675s at njmp all the time.
Old 11-08-12, 11:47   #8
Daytona.Scott
Here are the links regarding rsr triple fitting only r Model
http://www.facebook.com/permalink.ph...01448786567270
Here is a photo of the triple
http://www.facebook.com/photo.php?fb...6567270&type=1
Old 11-08-12, 13:11   #9
You are correct that the "R" does use a different lower clamp.
Ronnie is doing great work, but I would hardly call the Attack's clamps a "chunk" of metal though. They may look solid from the top, but if you look under the clamps you will see what he has done to make sure the correct amount of flex is there.
Here is the bottom view of the upper clamp:
Here is the bottom view on the lower clamp:
Also notice the machine work on the top side of the lower clamp:
Old 11-08-12, 13:40   #10
Daytona.Scott
Wow! I never got that view before :)
From the looks of it, attack is only listing triple clamp for 675 on their website. Do they make one for the r model?
