![]() Join Date: Oct 2012
This has been discussed a few times, but I was unable to find the information I'm about to lay on you, so I'm going to toss it in it's own thread for posterity.
When you remove the left signal controller housing most people like myself just jumped the clutch switch. It worked fine, but that is because I was not using a quick shifter. I have my shifter set to "GP shift" and the stock QS wouldn't work like that. Thusly, I didn't notice a thing. Well, last night I installed my new Push QS, and it didn't work. After a bit of fiddling I realized the QS would work with the jump removed and the housing re-attached. What was happing was, the ECU thought my clutch was pulled in, and was bypassing the QS. The fix: I removed the two wires (black & Black/yellow) for the clutch switch from the plug. Then I separated the clutch switch from the wire bundle so I could discard the left switch housing I was trying to get rid of. I put heat-shrink around the two remaining wires. Then I plugged them back into the Black, and Black/Orange wire on the plug from the harness. The whole thing took only 20 min, and works perfectly. I hope this helps. |
could you take a picture of what the wiring looks like? I'm having trouble following! haha
#3 |
Your ecm reads 15 codes off the clutch switch (09 and newer). You may have running issues.
Sent from my SCH-I500 using Motorcycle.com App
Slow is smooth, and smooth is fast |
#4 |
I did the opposite, I removed all the wires from the switch connector EXCEPT the clutch switch wires. This way I can just un plug the connector when needed, but the extra bulk of the switchgear is gone.
09 Street Triple 06 Track Triple |
#5 | |
Sent from my iPhone using Motorcycle.com Free App |
