<h1 class="pdpTitle">Mityvac MV8000 Brake Bleeding Kit</h1>
The original Mityvac hand vacuum/pressure pump kit is used by service professionals worldwide for performing hundreds of diagnostic and mechanical tests and for one-person brake bleeding. Product Features: <div id="productDescription"> <div class="paneHeightAdjust">Hand vacuum pump with 50 mm diameter pressure gauge. 135 ml fluid reservoir bottle with fluid transfer and storage lids. (7) Tapered adapters for connecting to tubing from 2.3 mm to 13 mm ID. (2) Tapered manifold plugs. (3) Bleed screw adapters. (2) 6.4 mm ID x 610 mm long connection tubes. 4 mm ID x 6.4 mm ID tubing adapter. 4 mm ID x 75 mm long connection tube. 6.4 mm ID x 40 mm long connection tube. 6.4 mm ID x 90 mm long connection tube. Rubber cupped adapter.</div> User manual (English/French/Spanish). <div class="paneHeightAdjust">This tool will make bleeding your motorcyle brakes or ATV brakes a very simple process!</div> <div class="paneHeightAdjust"> </div> </div> |
I own this and it works awesome!
http://www.loganwildphoto.com http://www.triumph675.net/forum/showthread.php?t=54106 23,500 miles and counting |
