Winterize vs Idling - Triumph675.Net Forums
Old 10-30-12, 12:04   #1
Tucker2.0
Tucker2.0's Avatar
Send a message via MSN to Tucker2.0
Default Winterize vs Idling
hey Guys
I was having a discussion about winterizing a bike with an older rider today. And he stated something interesting. Since he rides as much as possible even in the winter, He says he just walks out to the garage every 3-5 days and cranks it up. Lets it idle for a while and thats it.
Is this a viable alternative to completely winterizing your ride? Ive never heard of doing that before.
2007 SV650S -RIP suziQ
2010 Daytona 675SE -I miss my SV, but damn that daytona!
1980 Honda cm200t (running work in progress)
Old 10-30-12, 12:22   #2
bizzyballa31
bizzyballa31's Avatar
Old 10-30-12, 12:27   #3
Tbone675
Tbone675's Avatar
imo no. the hot/cold cycles will just cause internal moisture/condensation. there really isnt that much to winterize. add fuel treatment and remove the battery...
2009 KTM 690R
2010 Triumph Daytona 675 SE
Old 10-30-12, 12:54   #4
Tucker2.0
Tucker2.0's Avatar
Let me give some details. Still goes through the same summer maintenance routine, cleaning and lubing, checking seals ect ect ect....
But instead of winterizing he goes out and and cranks it up, and lets it run for half an hour or more, and puts a little oil around the suspension seals and works the suspension while he's at it.
Granted he has an older parallel twin from the 70's. Not too much different from my cm200t. And there is alot more to winterizing those than the daytona.
When he said he did that, he just baffled me.
Old 10-30-12, 16:55   #5
eldridge216
eldridge216's Avatar
you live in NC man winter isnt long enough or cold enough here to "winterize" your bike. put the battery on a tender, lift the bike up on some pitbull stands and she will be ready to go on those freak days we get in the middle of winter that are super nice and deserve a good ride
my avatar describes how i feel when im on my daytona
pin to win
Old 10-30-12, 18:37   #6
DecepticonDon
BOTM Marshall
DecepticonDon's Avatar
What would be the downside to his technique? His bike stays ready to ride.
Winterizing, from what I understand is to prepare the bike for 3-5 months of storage. Never winterized as there's not much of a winter in Southeast GA.
Also, not many people would have the dedication to spend that much time maintaining their bike in the off season.
Download TuneECU FREE!!! Click here...
"Constantly choosing the lesser of two evils is still choosing evil." - Jerry Garcia
Old 10-30-12, 18:49   #7
Nastybutler
Nastybutler's Avatar
Sounds like more work than winterizing it. I just put it up on stands, change my oil, put the fuel stabilizer in the full tank and disconnect the negative cable on the battery (LiFe battery doesn't really need constant tending). Done. Don't have to mess with it until I get it ready for Spring.
2012 Street Triple - Phantom Black (Trinity)
Trinity's Mod Thread
Old 10-30-12, 20:05   #8
Geof3
I live in CO so we have real winters. But even so, I can ride every now and then. I put mine on a tender and treat the fuel and that's it. I will move it around to avoid flat spotting the tires. I'll be doing big stuff too around January or so. Suspension stuff, 520 conversion etc. never had a problem with this method.
I don't think it is a good idea ever to let any engine sit and idle for a long period of time. In fact some car manufacturers recommend against it specifically.
Old 10-30-12, 21:39   #9
Tucker2.0
Tucker2.0's Avatar
I know right? it was in the 70's last week and now its in the 40's! and back to 60's over the weekend.
Im not going to let my daytona sit thats for sure, but the cm200t will sit a good bit more, still working on that.
Old 10-30-12, 23:01   #10
Smoke
Smoke's Avatar
Did a similar routine with my Ducati when I couldn't ride it yet, worked fine but it didn't prevent loss of charge from the battery, should've disconneted it.
Makes perfect sense when there are riding days in winter.
