Rims being powder coated, how to get rotors off?!? - Triumph675.Net Forums
Old 10-27-12, 23:10   #1
tuscani451
Default Rims being powder coated, how to get rotors off?!?
I did a search and found a very similar question/thread but there wasnt a lot of info about getting the rotors themselves off and i swear I broke something in my hand getting just two of the rear bolts off! I read to heat them with a heat gun or hair drier. I thought about seeing if the same shop could take them off but they are closed until monday and dont want to create a hassle for the shop. So if anyone has any tricks let me know.
Also I am not going to worry about getting the old bearings out as I will buy new ones and have the olds ones removed and new one placed after the PC. I could use recommendations for the replacement bearings though, I figure I will go ahead and get the best available since i have to replace them anyway.
Thanks!
Old 10-28-12, 00:07   #2
415TRIUMPH
415TRIUMPH's Avatar
i've used all balls bearings for replacements, though here's a thread that may help you with bearing selection;
[ame="http://www.triumph675.net/forum/showthread.php?p=302587"]Front Wheel Bearings and Dust Seals - Non OEM Replacement Part Numbers - Triumph675.Net Forums[/ame]
as for removing the bolts, they will need some heat to loosen up the thread lock
Old 10-28-12, 09:32   #3
allaussiegrown
allaussiegrown's Avatar
I found using a good torque head that had some length worked fine.
It did make a snapping sound. That is the movie and friction releasing
once you get your bearings out you can go to a local bearing dealer and pick them all up on the very cheap, including dust seals
I still get those 'oh shit' moments.... The day I don't, is the day I stop riding.
'11 675R
Werkes Slip On Pipe + STD Fender Elim + Intergrated Tailight - ZG Double Bubble DS - Dual HID Headlights and Angel Eyes with Coloured Headlight Housing - Red Seat Cowl - LED Strip Indicators - 1050 Throttle Tube -
Attack Reasrsets (Red Pegs) - Powdercoated wheels and Sidestand - GB protection Kit - CRG Levers folding - Saddlemen CF Track Seat - Watsens
Old 10-28-12, 10:42   #4
DecepticonDon
BOTM Marshall
DecepticonDon's Avatar
Heat....and before you try to loosen them, tighten them just till it moves slightly and makes a "tick" sound. it will take the tension off the threads and make it easier to remove the bolts. old mechanic trick
Download TuneECU FREE!!! Click here...
"Constantly choosing the lesser of two evils is still choosing evil." - Jerry Garcia
Old 10-28-12, 13:33   #5
tuscani451
Good info, thanks guys! I will try all of the above. Thanks for the info on the bearings as all. Yeah Allgrown, that snapping sound made me think I was stripping the head of the bolt :-(
Old 10-28-12, 14:37   #6
Ruby Racing
Ruby Racing's Avatar
Are you using an Allen head socket with a socket wrench or just a small Allen key?
Old 10-28-12, 15:49   #7
tuscani451
Just a small Allen key :-/ I don't have the correct socket but I will be picking up a full set today. I have been making due without a set for a while
Old 10-28-12, 18:01   #8
old blue
old blue's Avatar
That's it. A 3/8 drive with a quality Allen head bit is the way to go.
O.B
Old 10-28-12, 18:07   #9
Ruby Racing
That's why you're having trouble getting them undone then. They are Loctited in and you're not going to get enough leverage with a pissy Allen key. Time to expand the tool box contents.
Old 10-29-12, 07:51   #10
Godly
Godly's Avatar
That's your problem! I recommend ordering the full Hex Head Socket set from Snap On or another company, well worth the money IMO
"Faster we become, until the thrill of speed overcomes the fear of death"
