| Riders Discount Sponsor forum for Riders Discount |
As a Michigan-based company, Riders Discount is all too familiar with having painfully short riding season. We know many of you are also familiar with this unfortunate reality and, like us, try to keep riding as long as possible - despite the cold weather. One easy way to make your rides in these less than favorable weather conditions more comfortable is to use quality heated gear like the Alpinestar Tech Heated Gloves and Vest.
The Alpinestars Tech Heated gloves use a leather construction with textile, suede and polyurethane inserts for a high level of protection. In addition to the durable main leather construction, the gloves feature PU inserts in the sides, along the wrist, and PU armor molded across the knuckles. There is also extra padding along the top of all fingers. Rounding out the list of safety features is the Alpinestars patented finger-bridge connecting the 3rd and 4th fingers. These safety standards are similar to those you would expect to find on a top of the line pair of racing gloves. For weatherproofing, Alpinestars makes use of its Drystar membrane, which is both waterproof and breathable. This allows it to maintain heat while wicking away any sweat that would normally build up, leaving you with dry, comfortable hands. Heating is accomplished with a new active heating technology that heats up the gloves quickly and provides consistent heat over the entire hand. We tested the heating capabilities of these gloves in the shop by hooking the wiring loom up to one of our Ballistic Lithium Ion batteries. The gloves were up to temp in only 3 - 4 minutes and we measured a maximum internal temperature of 107° F with our infrared thermometer. The Alpinestars Tech Heated Vest is a lightweight mid-layer that keeps you warm without the need for bulky insulation. The ultra-comfortable vest uses flat polymer heat panels in the chest, shoulders, neck and lower back to evenly distribute the heat without creating hot spots. This is further aided by the insulating properties of the lycra outer shell and mesh internal lining that allows heat to easily pass through to your body. In order to keep you warm and dry, Alpinestars added breathable side panels to help wick away moisture. Power for both the vest and gloves comes directly from your bike’s battery, so wiring is very simple. The wiring kit for both is sold separately and comes with everything needed to run the vest and gloves together or individually. An optional Electronic Temperature Regulator (ETR) can also be added to the vest for your choice of four different temperature settings. The Alpinestars Tech Heated Gloves and Vest are a great way to keep warm and comfortable when the weather doesn’t cooperate, and Riders Discount is happy to help you get you set up. Be sure to get in touch with TJ if you’re interested. He can be reached through this forum or by phone at 866.931.6644 ext. 817. If email is more convenient, feel free to send those to FORUM at RIDERSDISCOUNT dot COM and we’ll get back to you right away! ![]() A mesh liner in the vest allows heat to travel evenly from the heating elements to your body. ![]() The lycra outer shell helps keep heat in, while mesh sides wick away built-up moisture. ![]() Alpinestars Tech Heated Gloves ![]() The Tech Heated gloves feature the Alpinestars finger-bridge and molded PU knuckle protectors. ![]() The cuff features double layer construction to avoid thermal bridges and a storm gauntlet to fit over jacket sleeves and keep the elements out. ![]() The controller kit is required to run the gloves/vest and it includes everything you need to run both of them. It comes with: Battery wiring loom with inline fuse (37”), extension cable (24”) and a long Y split harness (94”) that allows you to route the connection points wherever you prefer on your bike.
Price to 06457 please.
#3 |
#4 |
Price for gloves vest and controller to 27577.
#5 |
#6 |
Make the Alpinestars Tech Heat gear even more versatile by adding the ETR controller. This controller allows you to power the gear on and select between three different heat settings. The large circular button is easy to use with gloved hands and features LED lights that change colors to show you which setting you have selected at a glance.
![]() With each press of the button, the ETR controller will change between green (30% heat), yellow (60% heat), and red (100% heat).
#7 |
Price for the whole kit to 43015 please.
#8 |
Can I get a price break down to 85138
#9 |
price for the whole kit to 80918
Thanks
2010 Tornado Red 675 - Vela 2008 Xterra OR - Jaws |
#10 |
whole kit to 76522 please
06 Graphite Daytona "Mostly Stock" Thanks Dad you were right again |
