The tuneboy live maps are on the tuneboy site, we now have the ability to use the side stand switch as a qiuckshifter, my question is does anyone have any pics of where to mount the new switch, i presume it will need to go on the shift rod. I am sure someone on here posted a few months ago he got his working but i cant find the post now.
#2 | |
But how does it even work with a piece of software and the stock ECU. Can someone explain? |
#3 |
I don't know about this specifically, but most add on traction control systems work by calculating RPM rise for each gear. If the RPMs increase too fast, it cuts fuel. You have to set it up and make the necessary adjustments.
09 Street Triple 06 Track Triple |
#4 |
Heh, have you seen the interview with Mat Mladin a few years ago when he talks traction control? Think about all the tuning experience that team has and he says getting it set up is a real PITA, all about compromises, at least for the level riding they do.
2012 Daytona 675 |
#5 |
i have had a try at downloading the map to bike, but i cant get it to work at the min. i have a idea for the switch mount...i will try again tomorrow on a diff laptop.
#6 |
Cool, keep us updated. I'm definitely curious about this. And take some pics if you find a nice solution.
2008 Daytona 675 with a 2009 identity crisis. Performance - BMC Street filter, Leo Vince full exhaust, TuneBoy w Flux's tune, Anti-slosh tank foam, APE CCT, Pitbull 520 sprockets w DID ERV3 Cosmeticish - Watsen indicators front and rear, CRG levers, Techspec's, LSL sliders, Gilles axel adjusters, Evotech fender, Triumph clear brake Expendables - Pilot Pures, Straight distilled w water wetter, Motul 300v 15w50 oil, CL C59 brakes, Motul brake fluid |
#7 |
well things are looking up, installed the map off a different computer no problem, must be a driver issue on my laptop. tested the map switching, looks like its working. just the bracket to knock up and switch to wire in.
#8 |
You need to Race ECU for this?
#9 |
no its all working on a standard ecu. there is a separate tune for the race ecu.
#10 | |
Is there a manual or something to make the switch/bracket? |
