Which tune to use for Akrapovic Full system - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Daytona 675 & Street Triple 675 Global Forums > Modifications > All Things Tuning
Old 08-07-12, 01:19   #1
Fithos
Default Which tune to use for Akrapovic Full system
I installed a Akrapovic Full Exhaust System on my 2011 675 and was wondering if anyone has this exhaust and which tune are you using with it? I will be using TuneECU to put on a new tune. Also, my check engine light is one because I removed the exup valve. Any way to have the check engine light ignore the exup valve?
Old 08-09-12, 08:32   #2
sgissel
Hey i have a tune that i have been using for some time with the full system, it has been made with power commander autotune. i made a lot of difference from standard map. i can mail it to you if you want it ?? but it is for PC V
You can disable the Exup valve in tuneecu, that should fix your problem
Old 09-10-12, 04:43   #3
675R-Jakarta
Hi,
I am a new member. I am from Jakarta- Indonesia.
Last night i installed Akra full system and surprised that engine check is on. And I read this thread. My mechanic say it is normal. Is it normal? My previous bike R6 does not.
I also install PC-V
Old 12-12-12, 23:37   #4
JayP
JayP's Avatar
I have the full akra system on my street bike and Im running the Arrow full system tune.
IMHO fuelling seems fine and everything seems peachy. Of course a power commander and dyno tune might be nicer but as my road bike im more than happy with that tune and for FREE :)
On the track i very comfortably pulled away from a stock 675 on the straight that admittedly had a far better rider on board
Road - 2013 675R
Road - 2009 675se
Track - 2006 675
Track - 2006 R6 sold :(
Old 12-15-12, 20:59   #5
jdgun_13
jdgun_13's Avatar
After my expeirence with using a FREE (TUNE ECU) map, they are decent for getting by until you get a custom tune..
The difference between the TUNE ECU full system map, and my custom bazzaz tune was 7rwhp & 4 ft lbs of torque, we are talking huge differences here..
I think the difference is worth a add on fueling unit and custom tune.. or at least find someone to custom tune your Stock ECM.
2005-ZX-6R
2011-675R Far to many mods to list
2012- RSV4 Aprc Factory
