Optimal Racing fairings - Triumph675.Net Forums
post #1 of 34 Old 04-24-12, 20:47 Thread Starter
RedAndBlack
RedAndBlack's Avatar
I have browsed the forum about these fairings and still have a few questions. I appreciate any feedback.
1. Are these fairings designed to fit the 2008- windscreens or the 2009+ windscreens? And just to verify, other then the windscreens, the fairings should fit fine on all models?
2. What's the deal with the Supersport to Superbike tails? Why do you guys prefer one over the other? Seems like people favor the Superbike tails but I still don't understand why. Is it something beyond crash protection?
3. Any problems with fit?
4. Did your fairings come with any mounts, specifically the D rings?
5. What is that burning sensation in my pubic region?
Thank you in advance.
RedAndBlack is offline
post #2 of 34 Old 04-24-12, 20:51
Knolly
Knolly's Avatar
I don't have them, but for #2, superbike tails tend to be preferred for track riding because they are less weight than having a separate seat, allow for more "feel," and like you mentioned, in the event of a crash, it's one less part to replace.
2015 Ninja H2
2013 Street Triple - Sold - Egotistical Bike Thread
2009 Ninja 250 Track Bike - Sold
2009 Daytona 675 - Sold - Self-Indulgent Bike Thread
2008 Street Triple - Sold
Knolly is offline
post #3 of 34 Old 04-24-12, 23:41
bcmoore
bcmoore's Avatar
1. Designed to fit the 08 windscreen, but other than that will fit any year bike..
2.. I went with the supersport tail.. no real reason..
3. No problems with the fit, but you might want to look into reflective heat tape for the inside of the fairing (applies to all aftermarket fairings)
4. My package ordered directly from Optimal did not come with any fasteners or D-Rings.. I did buy some nylon washers to use under a few of the screws because the the fiberglass was to thin and the screws bottomed out before they tightened up on the fairing
5... Dude go to the doctor...
bcmoore is offline
post #4 of 34 Old 04-24-12, 23:57
frayed
frayed's Avatar
I remember sending back a mistakenly sent 09 windscreen since it did not fit, so yeah, the older windscreens. I had no personal issues with fitment. Have needed no heat resistant tape as I have plenty of clearance though they are a bit more tight to the radiator than my last set of bodywork.
I went with the superbike tail and chose the thinnest seat foam because I wanted to be more down in the bike. IMO the 675 seating position is a bit too perched up top.
CCS AM#413
Please support my sponsors: www.WickedRacing.com - Go-fast parts and gear for riders and their motorcycles
frayed is offline
post #5 of 34 Old 04-25-12, 11:49 Thread Starter
RedAndBlack
Thanks for the input gentlemen. I placed my order this morning and guess I'm going to have to find a windscreen. Let me know if someone is willing to part ways with one.
post #6 of 34 Old 06-13-12, 22:24
leophliao
I just received the full set from Optimal Racing for my 2010 D675, got it for like $400 shipped, but need some help about the fitment, what do i need to put the fairings on, what kind of fairing stay etc. New to the track and need some advice, and what kind of 06-08 windscreens do you guys recommend? thanks
leophliao is offline
post #7 of 34 Old 06-13-12, 23:33
chuxter
chuxter's Avatar
I have a Puig windscreen and I use some of the stock fairing side bolts, along with a set of 6 Dzuz fasteners.
2008 Daytona 675,... the dolphin in my swimming pool
chuxter is offline
post #8 of 34 Old 06-14-12, 19:09
leophliao
Thanks for the reply, are the fasteners for connecting the upper and lower fairings? Where should i drill the holes for those? and what kind of fasteners from Dzuz should i get?
once again thanks
post #9 of 34 Old 06-14-12, 19:13
leophliao
post #10 of 34 Old 06-14-12, 20:13
chuxter
chuxter's Avatar
Originally Posted by leophliao View Post
Those are the exact fasteners needed. You will need to drill 2-3 holes parallel along where the upper and lower fairings connect on both sides of the bike. I drilled 3 holes per side of the bike, but I've seen people only use two fastners per side. Since I had 6, I used all six.
(Make sure you have the fairings marked/matched up well before you drill the holes so that connecting the fasteners keeps your fairings together real snug and tidy. I rushed on the last hole and wound up with a minute amount of disconnect between upper and lower fairing)
Name:	Optimal Racing.jpg
chuxter is offline
