I thought you guys would appreciate this... I installed a 5V 3A USB charging port on the right infill panel. The port is waterproof and is using a voltage regulator meant for radio controlled airplanes to provide the juice. An iPad requires 2A to charge, so this is more than enough to power a few devices at once.
I'm not really great with a Dremel so I may try to get a new infill panel and cut it with a CNC. To keep the wire under control, I'm going to use a waterproof USB extension cable with a right-angle plug to feed into my tank bag. ![]() ![]() ![]() ![]()
HMMM... I'm not very knowledgeble when it comes to PC electronics, but how about using that for Go Pro camera?
Nuno!
Noodles Racing would like to thank the following sponsors for their support in the 2012 CSBK season: GP BIKES TRIUMPH, EUROCORSA PERFORMANCE (Bitubo suspension, Spidi leathers, Rizoma rearsets, Power Bronze windscreens), ARMOUR BODIES, MOTOAIRBAG CANADA, MOTOVAN, HINDLE EXHAUST. http://s21.photobucket.com/albums/b294/Noodles_771/ |
#3 |
got one of these under my seat to charge my extra gopro battery
#4 |
Noob Hazer
What about water? I would get some kind of cover for it.
2010 TornadoRed D675 ~ |
#5 |
![]() Join Date: Oct 2009
Looks like you have a cap on the top for water but what about on the other side of the panel?
Definitely a clean install though, nice work!
2009 Triumph Daytona 675 - Dedicated Track Bike - My Self-Indulgent Bike Thread |
#6 |
Great mod. Been thinkin of doing this instead of the sae>cig adapter>cig usb charger>phone/gps/GoPro whatever. Nice to see it works. Thanks for the motivation
Scorpion CF slip-on, Catalyst Composites tail, CA smoke tail light, BC FE, rear brake res delete kit, Danmoto rearsets, Driven D3 grips/barends, JPR shorty levers, Puig DB windscreen, full T-rex slider set, SSR preload adjusters, Proton flushmounts, exup delete, blue Angeleyes, Stompgrip, Q2's, Roaringtoyz mirrors
#7 |
I love having a USB Port on my bike
![]() But I put mine near the handle bars and I have a craddle for my phone to sit in that is very convenient; having a full charge on the phone always while riding and streaming music is great
I my Black Rocket!
#8 | |
http://search.digikey.com/us/en/prod...-00-ND/1242675 I left the two data pins exposed on the bottom in case I find a use for them but a blob of hot glue would probably take care of that. |
#9 |
There are actually quite a few nice USB ports on the market. Powerlet has a couple options and are coming out with more. 3A is a little high, I would not plug a GoPro into that.
#10 |
Er, it just _can_ give out 3A, it's not _forced to_, is it ?
The slower you move, the more dangerous your bike is... I'll let you work out the conclusion from there ![]() If you find wearing proper gear's too hot, you're just not fast enough ! ![]() Dual Desert Eagle EBB ? MER IL ET FOU ! Viendez nolifer avec nous sur le salon #Airsoft sur IRC ! Et jouer avec Ploubalairsoft entre le 22 et le 35
