Bazzaz Triumph 675 QS4 Quick Shifter Kits Now Available - Triumph675.Net Forums
Old 07-25-11, 12:02   #1
Default Bazzaz Triumph 675 QS4 Quick Shifter Kits Now Available
Now available from Bazzaz Performance Design, the QS4 USB stand alone quick shifter system brings quicker acceleration and lower lap times to you at a reasonable price without the need to purchase any additional components. The Bazzaz QS4 works with both, your motorcycle’s stock ECU and any engine tuning system such as Bazzaz’ own [ame=http://www.triumph675.net/forum/showthread.php?t=43250]Z-Fi fuel control system[/ame]. Now, full throttle clutchless upshifts are possible thanks to this simple plug and play device that requires no permanent modification to your Triumph 675. The QS4 comes with a model-specific wire harness, programming software with USB interface cable, control hub and a shift rod/sensor system that allows you to install the quick shifter on and go with no need to purchase any extra components. Should you need, the included software allows you to tailor the quick shifter to your specific requirements with individual cut out times that can be set for each gear.
Bazzaz Performance QS4 USB kits are not yet available on our website - call TJ at 866-931-6644 ext 817 to order today. You can also email us: FORUM at RIDERSDISCOUNT dot COM with TRIUMPH 675 BAZZAZ QS4 in the subject line and tell us whether you want a reverse or standard shift pattern and we’ll get back to you right away.
The Bazzaz QS4 as it comes out of the box: zip ties and Velcro are included to secure the wiring in a safe, workman-like manner for safety and long-lasting performance.
The heart of the QS4 quick shifter system is the USB hub itself and the shift rod sensor which is available in either your choice of standard or reverse shift patterns.
The QS4 system comes preprogrammed with model-specific shift kill times set at the factory. These kill times were developed in-house at Bazzaz Performance based on real-world testing at the track so there’s a good chance you won’t need to change them. Here is a screenshot of the QS4 USB system user interface. The device can be programmed while it’s attached to your bike or, you can take it to a desktop computer and hook it up to make changes. All of this is done with the included USB cable.
The QS4 USB comes with a gear position sensor interface already installed, so there is no need to calibrate gearing to use the system on bikes with stock internal transmissions. For those of you changing internal gear ratios, Bazzaz Performance has included a gear position calibration table in their software that allows you to easily make changes for kit transmission parts. The recalibration process is simple and effectively allows accurate gear-specific cut-out times to be programmed for all riding conditions.
The Bazzaz QS-4 works perfectly with OEM or aftermarket rearsets like these from [ame=http://www.triumph675.net/forum/showthread.php?t=44021]Attack Performance[/ame].
Old 07-25-11, 13:05   #2
WiK1d
WiK1d's Avatar
Will these work on first generation Daytonas without the race harness?
www.bertusras.com | @bertusras
'07 Derbi GPR125 2T | '07 Triumph Daytona
Old 07-25-11, 13:38   #3
You are correct you can plug this into the OEM harness on the 06-08
Old 07-25-11, 15:07   #4
umicheng
umicheng's Avatar
Send a message via AIM to umicheng
ohhh curious, price please :)
2007 Daytona, Track (Chase)
Past Loves
2010 D675 SE, Street (Tristan)
2007 Ninja 250R (Scott)
Old 07-25-11, 15:11   #5
Old 07-26-11, 13:04   #6
air_odie
air_odie's Avatar
Location: Currently in Ft. Irwin, CA (sadly) --soon FLA USA
Send a message via Yahoo to air_odie
hit me up witha pm as well please
keep the shiny side up and the rubber side down!
--ALL WORK AND NO PLAY MAKE ODIE GO HE HE HAY HAY!!!
Old 07-26-11, 13:08   #7
bcmoore
bcmoore's Avatar
Price check please
Old 07-26-11, 13:09   #8
WiK1d
WiK1d's Avatar
I know I shouldn't, but price check please!
Old 07-26-11, 13:53   #9
You all have PM's now.
Old 07-26-11, 16:29   #10
Bluehaze
Bluehaze's Avatar
dammit.. i just got done buying from you.... ok..i'll bite. PM please to 98208.
You know anyone that has this with Gills Rearsets?
Tags
bazzaz performance, bazzaz qs4, bazzaz quick shifter
