| News, Announcements, Tests and ride reports any and all 675 ride experiences and news |
#11 | |
![]() ![]() Make sense now? Last edited by coreyvwc; 02-19-11 at 01:01. |
#12 |
Yeah I'm sure it has a lot of power but power is not an issue with regular brakes it's all about control and reducing rotating mass both of which this system seems to be a huge step back on.
#13 |
not sure on the control factor, but this setup actually allows for less rotating mass which is the whole reason for the design. The perimeter mount rotor allows them to use a much lighter front wheel because there is less stress being applied on the rotor lugs, thus less material is needed. Plus there is only one rotor without a carrier attached to the hub. Then there is only one caliper, one brake line, two brake pads which makes the entire front end lighter. The important thing to remember about Buell is that form ALWAYS follows function.
#14 |
Yes it weighs less but due to the larger diameter it actually has a higher amount of radial momentum and thus more gyroscopic force then two smaller discs. More gyroscopic force means it's harder to change directions.
#15 | |
My first thought was a Honda/yama cuz of the fender, anything but a Buell Edit: sry i gotta say i love the single pivot style shock Last edited by KRS; 02-19-11 at 03:41. |
#16 |
always amazes me how a little bit of plastic can take an ugly as sin buell (imo) and give it the same profile as the rest of the sport bikes we love.
thumbs for for trying something new with the exhaust, but it sucks. am i the only one that is bothered by the wheels not matching? triggers the ocd every time i look at it. |
#17 |
I think its more then ski deep this time. Their using a Rotax 1190 motor which I have to assume Ian the same Rotax 1190 that KTM uses in the RC8.
#18 |
The front and back wheel never match, the rear being bigger, ya know... And it is indeed the front rotor setup which allows such a thin front wheel (and doesnt allowa thin rear wheel, just live with it. I'm pretty sure Erik took everything in account, but I still think a double system would be preferable to avoid fork twisting. I'll live with it, too.
That said, at long last a decent-looking Buell
The slower you move, the more dangerous your bike is... I'll let you work out the conclusion from there ![]() If you find wearing proper gear's too hot, you're just not fast enough ! ![]() Dual Desert Eagle EBB ? MER IL ET FOU ! Viendez nolifer avec nous sur le salon #Airsoft sur IRC ! Et jouer avec Ploubalairsoft entre le 22 et le 35
#19 |
I would have to disagree to certain extent. I believe you would actually have less gyroscopic effect from the front wheel with the rotor being on the outside of the wheel. Less weight and less mass centralization being forced when the bike is heading into a turn. The front end on that bike must be incredibly light. Have you pick up a caliper, disc and hub. Their is probably over ten pounds per side. Also with the exhaust I think it's funny how everyone wants to be different and rides a Triumph yet when someone comes out with a different looking exhaust everyone wants the same looking exhaust off of another bike.
http://www.loganwildphoto.com http://www.triumph675.net/forum/showthread.php?t=54106 23,500 miles and counting |
#20 |
For any given weight and rotational speed the larger the diameter you make it the more gyroscopic forces that it will develop. This has to do with the corresponding speed of the two objects. Just like on a race track where the inside line is the shortest distance the outer line is longer so in order for the disc around the outside of the rim to make one rotation it has to travel at a far greater speed thus developing more momentum and more gyroscopic forces.
