How to remove intake flapper valve - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Daytona 675 & Street Triple 675 Global Forums > Maintenance and repair > How To's
Old 09-27-10, 19:53   #1
matthewo
matthewo's Avatar
Default How to remove intake flapper valve
So i took my front fairings off so i could clean them good. saw all the intake valve crap. I have a tuneecu tune with the intake flapper turned off, so why not just remove it all.
1) unbolt front fairing bolts
2) remove windscreen
3) remove mirrors
4) you dont have to remove the side fairings but i already had them off so it helped
5) i allowed the whole front fairing to drop down and sit on top of the front fender
here is the picture with the fairings off
6) remove grill, it has to pins you must pull the rubber around so it pops off
7) now unplug the hose from the intake flapper unit above the intake tube, now turn the intake flapper unit 90 deg. and pull it up enough so you can remove the hook from the actuall flapper.
flapper control unit.
8) now you have it disconnected and removed, your going to need to loosen a lot of screws on the intake tube. the intake tube is a split design, its cut in half in the middle, and there are phillips screws on top and bottom, your going to need to loosen almost all of them to get the flapper out.
here is a picture of a bracket your going to have to remove to get to a screw that is hidden. there are also 2 10mm bolts you need to remove.
9) you can now push the intake tube apart a bit and pull the flapper out
10) now if you want to can cover up the hole, i used some 3m double sided tape i had laying around, it holds up to 5 lbs and i used it on car emblems that you can hardly get back off with a screw driver. you can use anything ugly or leave the hole open, you cannot see it with the bike back together.
11) now you can remove all the hoses, if you are not tuned you need to leave the electric connector on the solenoid connected, i left it connected even tho im tuned. you will have 1 hose that runs to the engine, under the tank, i pulled my tank up but could not find where it went, so i plugged it with a screw and zip tied it in there.
Old 09-27-10, 22:13   #2
i NO need hellmits
i NO need hellmits's Avatar
if you disable it in tunecu does it stay open all the time?
'09 black D675
Current Mods: TechSpecs, HIDs 8000K hi and low, Puig windscreen thanks to the EX-gf :(, ASV levers, CA integrated tailight, proton turn signals, British Customs Frame Sliders, Akrapovic slip on, removed exup, and Attack rear sets.
Old 09-27-10, 22:18   #3
matthewo
matthewo's Avatar
mine did, when i set it to 900 rpms in tuneecu.
Old 09-27-10, 22:25   #4
i NO need hellmits
when i set mine to always be open it kept making a strange buzzing sound.
'09 black D675
Old 10-06-10, 10:41   #5
silverspecv675
New to my 675 but whats the purpose of this mod? More low end?
2005 Toyota x-runner 383 hp/428 ft@7 psi
2003 VW Jetta 1.8T
2007 D675
Old 10-06-10, 10:59   #6
Aviator
Aviator's Avatar
It doesn't accomplish a ton in terms of performance. It is more of a nuisance reducer. The intake flapper is set to open at really low RPM anyway (I think like 2400 RPM or something like that). It does tend to get stuck, or squeak as it wears out. Ultimately it is just added weight, and another thing to fail.
Old 01-19-11, 06:01   #7
Karl
Karl's Avatar
My one used to squeak!
It drove me mad trying to figure out what the hell this friggen EEEEK was when I pulled in to home and turned it off!
And my ever so helpful wife and daughter…
Jax (wifey) “Maybe it’s a mouse?”
“I don’t think it a mouse.”
Elise (daughter) “It’ll be a dolphin then, they get everywhere…”
See what I have to put up with!!?!??!
Old 01-22-11, 09:15   #8
Bamboo671
Bamboo671's Avatar
Send a message via Skype™ to Bamboo671
LOL! I understand your pain. Wifey is a smart ass with me too and my daughter is always narcing on me when I go "out to my girlfriend!"
1997 YZF100R/Thunderace - 12 o'clocked it!
2008 Jet Black Daytona 675 - I called her Tasi!...she's dead!
2013 Daytona 675R - Her name is Tasa!
Old 04-11-11, 11:18   #9
hazexban
Chatbox Comedian & Race Team Sponsor
hazexban's Avatar
The pics are gone!
TPM: RED
COME BE APART OF THE TRADITION!
2013 TRIUMPH 675 Track Day, Open to all!
CLICK HERE SIGNUP!
FUNNY READ about kickball and my arm
Old 05-09-11, 23:18   #10
Bamboo671
Bamboo671's Avatar
Bump for the pics!
