Attack Performance Triumph Daytona 675 Adjustable Rearsets **NEW AND IMPROVED!** - Triumph675.Net Forums
Old 07-26-10, 12:49   #1
Default Attack Performance Triumph Daytona 675 Adjustable Rearsets **NEW AND IMPROVED!**
Attack Performance created rearsets for the Triumph Daytona 675 with ease of use in mind. These fully-adjustable rearsets are unique in that they allow the Triumph to retain its OEM through-the-frame shift rod routing regardless of whether you’re running a standard or reverse shift pattern. This is achieved through a clever bellcrank design on the backside of the left footpeg so fewer parts are required to assemble the rearsets and there’s no need to add special brackets to the bike if you wish to use a GP shift pattern. All Attack Rearsets are machined from 7075 T6 aluminum alloy which is fifty percent stronger than the 6000 series metal used by some manufacturers. This is advantageous in that parts can be made thinner (read, lighter) while still being just as tough at the same time. Developed with the knowledge that comes from years of on-track experience, each rearset footpeg can be adjusted not only back and upwards, but you can also adjust their angle for maximum grip. Toe pegs too, can be moved for reach.
These new Attack Performance Rearsets now include folding shift AND brake pegs for improved crash-survivability performance!
These are not yet available on our website, call TJ at 866.931.6644 ext 817 to get these Attack Rearsets shipped to you fast. If you have any questions, please send us an email: FORUM at RIDERSDISCOUNT dot COM with ATTACK 675 REARSETS in the subject line and we’ll get back to you right away.
Comes with everything seen here, including carbon fiber heel guards for both sides of the bike.
All hardware is of the highest quality for durability and corrosion resistance. Spares are readily available too!
Footpegs are engineered for light weight and crash survivability. Each peg is designed to break away at a specific point in the event of a crash so you’ll likely have enough left to ride the bike safely back to the pits - or back home, without the need to call for help.
As seen here, a wide range of adjustment is available. In addition, all moving parts use ball bearings for a smooth, positive feel when braking or shifting.
The bellcrank mechanism is simple and allows the use of either normal or reverse shift patterns without the need for any special brackets or having to route the shift rod anywhere but through its OEM location.
Attack adjustable rearsets provide an outstanding combination of features in a deceptively simple design. They’re durable, lightweight and reliable. [ame=http://www.triumph675.net/forum/showthread.php?p=631844#post631844]Here you can see exactly how to reverse the shift pattern[/ame]
Here's how they look on the bike.
It's nice that these rearsets use the OEM shiftrod location regardless of whether you choose standard or reverse shift. And, if you're using a [ame=http://www.triumph675.net/forum/showthread.php?t=43250]Bazzaz Z-Fi with a quick shifter[/ame] the installation is very clean with the pressure sensor behind the carbon fiber heel guard. To the casual observer, only the gray wire gives away the quick shifter.
Old 07-26-10, 12:53   #2
hazexban
Chatbox Comedian & Race Team Sponsor
hazexban's Avatar
These look AMAZING!
Still trying to decide if I want to go nuts today and make a big order with you guys!
Bump for a great place to buy from!
Old 07-26-10, 13:18   #3
WiK1d
WiK1d's Avatar
Oh jeeze those are nice. Seems I'm gonna spend a lot of money at RidersDiscount soon. Price please! Also, prices on spare pegs please!
www.bertusras.com | @bertusras
'07 Derbi GPR125 2T | '07 Triumph Daytona
Old 07-26-10, 13:48   #4
M335i
price? thanks
Old 07-26-10, 14:48   #5
Default Attack Performance Rearsets in Black for Triumph 675
Brake lever is adjustable for reach and also features a folding function for improved crash survivability.
Rearsets are adjustable over three positions on both the X and Y axis.
Adjustable shift mechanism makes switching between standard and reverse shift pattens easy.
Old 07-26-10, 15:28   #6
wuzertheloser
wuzertheloser's Avatar
price?
Attack life. It's going to kill you anyways
Old 07-26-10, 16:07   #7
Old 07-26-10, 19:26   #8
MTNRider
MTNRider's Avatar
Can you PM me a price please.
Thanks
Old 07-26-10, 22:08   #9
wingman44
wingman44's Avatar
price please
-Rob
Old 07-27-10, 06:08   #10
mjkuhno
mjkuhno's Avatar
Wow!
OK, I know I'm going to regret asking, but can you please PM me a price TJ for the rearsets and separate price for spare pegs?
Thanks.
BTW - if anyone hasn't ordered from Riders Discount yet - they're awesome!
- Mike K
'07 Daytona 675
Tags
675 footpegs, 675 rearsets, adjustable footpegs, adjustable rearsets, aftermarket rearsets, attack rearsets, daytona footpegs, footpegs, rearset footpegs
