Daytona is gettin' nekkid - Triumph675.Net Forums
Old 07-06-10, 15:08   #1
DecepticonDon
BOTM Marshall
DecepticonDon's Avatar
Default Daytona is gettin' nekkid
After downloading the TuneECU program and deleting o2 sensor, exup, and evap can, I decided it was time to mod even more.
--Got rid of the stock tag bracket /fender
--The wiring harness got chopped and relays and fuse box tucked under the tank.
that's all for now. Its gonna be a work in progress which is meant to be ridden so I've still got the stock headlights on it for the time being.
Download TuneECU FREE!!! Click here...
"Constantly choosing the lesser of two evils is still choosing evil." - Jerry Garcia
Old 07-06-10, 16:51   #2
benroe
benroe's Avatar
hell yes!!
675TT
Old 07-06-10, 17:22   #3
NewShockerGuy
NewShockerGuy's Avatar
Arrow
Don,
Noticed that you took the EXUP shit off... however I can't tell from your box of parts but I can see some exup parts via the backing plate to the spring but did you leave the spring on the exup valve so that it's kept in the open position? If not you will want to put the spring in place so it keeps it open rather than it spinning if it's not then my bad... just can't tell from the pic..lol
Also take that damn bracket off that used to hold the exup motor black box of death to the bike!
hahah
Looking good!
-Nigel
~NSG~
Old 07-06-10, 18:36   #4
DecepticonDon
BOTM Marshall
Originally Posted by NewShockerGuy View Post
Don,
hahah
Looking good!
-Nigel
Thanks for looking out! I took the spring off, but put a couple of lock washers and the original nut back on the exup. you can turn it with a wrench, but it doesn't move easily. Check it everytime to make sure it stays open. Hopefully soon I will be cutting the oem collector off and installing one like Kegsdale did. With a low mount exhaust of course.
Gonna take the bracket off, soon as I find my torx bits.
Old 07-06-10, 19:40   #5
Sparker
Sparker's Avatar
Originally Posted by DecepticonDon View Post
Old 07-06-10, 22:01   #6
DecepticonDon
BOTM Marshall
Originally Posted by Sparker View Post
Thanks. I'm glad you likey
The wiring harness wasn't as difficult as anticipated. although I was hesitant to make the first cut(like standing there for ten minutes with wire cutters in hand), just took my time and labeled every wire that was to be cut. Had to shorten some wires, had to lengthen some wires. For example, just used the wire from the exup(5 wires about 2ft each) when I had to add to the harness. Except for the headlight, which used a heavier guage wire.
Old 07-06-10, 22:40   #7
Scooter Scott
(RIP) Wiser than you I was
Scooter Scott's Avatar
Dude, save a little mod money for some paint on that shed. I hope its just your shed. And what are the dome thingies on the roof. Alien protectors?
Carbon fiber, the new crack?
Old 07-06-10, 22:49   #8
DecepticonDon
BOTM Marshall
That's an old two-room house. It right next door to my buddies place.
Come now, you surely know what a lightning rod is. I think those people were very afraid of lightning
Old 07-07-10, 00:04   #9
doublen675
doublen675's Avatar
...That's a shitload of wires!
//Double "N"
The Exhaust Reference Thread - My Thread - All About Oil
Bike of the Month Submissions...
"When Life Throw's You a Curve...Lean Into It."
Old 07-07-10, 00:22   #10
Sparker
Sparker's Avatar
I just noticed that your brake reservoir matches your avatar.
