Go Back   Triumph675.Net Forums > Daytona 675 & Street Triple 675 Global Forums > Modifications
Modifications mods and sods.... for show and go. Our busiest forum
Old 02-08-10, 00:10   #1
mgaul1
mgaul1's Avatar
Default LSL FRAME SLIDER, install..HELP!!
So I bought some LSL frame sliders for my 2008 daytona 675, question. There are 2 screws that go into the bike, one for radiator mount and other for cylinder head frame, my question is as far as the cylinder head frame the original nut that's on the other side is it a FIXED nut or a nut not attached to the bike because with its location i feel like it'd be impossible to get a rachet in there to hold the nut while i unscrew the original engine bolt...so, before i get into this, is it a fixed nut? and is there any advice for installing these frame sliders??
Thanks!
Michael
2008 Daytona 675 Special Edition
Old 02-08-10, 00:42   #2
Ken M1
Ken M1's Avatar
I have sliders on my Street (although not LSL's). I'm pretty sure it's the same Street/Daytona. The front engine bolts have a nut behind them that is NOT fixed (where as the rear engine bolts thread directly into the motor). It seems as though it is, at first, because it is the "stippled" locking type nut that grips the motor's surface. Once the tension is loosened though, it's free and clear. You'll have to get a wrench behind there to take it off (or it will keep spinning and not come off). I accessed mine with an S shaped box wrench for shift side, but loosening the radiator is generally the better way to go (which I had to do for the brake side). Loosen the top rad bolts, remove the lower bolts, and swing it out about 1 1/2" (yeah, it doesn't move much). The motor bolts are SERIOUSLY tight, I had to use a breaker bar to crack 'em loose. I forget the exact torque spec, but I seem to recall using around 34 lbs to tighten back up (front and rear).
Old 02-08-10, 00:45   #3
415TRIUMPH
415TRIUMPH's Avatar
i used a long extension and a swivel socket to get to that nut
Old 02-08-10, 02:16   #4
mgaul1
mgaul1's Avatar
Kickass, guess I'll go get some new tools tomorrrow and take this thing on, sure wish that was a fixed nut however that would make it quite a bit easier but owell! Thanks for the quick reply guys I appreciate it
Old 02-08-10, 18:00   #5
Steve09675
Steve09675's Avatar
Tighten the 2 motor mounting pointsto to 48 Nm. The instructions have the rest of the torque specs.
Steve
2009 675, Arrow slip-on, solo seat, pazzo levers -long clutch/shorty brake, carbon fiber bits, watsen's, LSL Frame/Clutch slider, soon to come - woodcraft rearsets/clip-ons.
Previously owned bikes:
2009 BMW R1200RT, 2005 Kawi ZX10R, 2003 KX250, 2001 XR400, 2000 ZX6R, 2000 ZR7, 1995 DR650, 1983 YZ80, Rupp Hustler
Old 02-08-10, 21:52   #6
Ken M1
Ken M1's Avatar
48Nm = 35 lb-ft
Old 02-09-10, 04:55   #7
Hands On
Hands On's Avatar
Send a message via AIM to Hands On
I believe I was able to get a box wrench in there when installing my LSL's to hold the nut. Still did the turning using a hex socket.
Old 02-10-10, 09:45   #8
mgaul1
mgaul1's Avatar
I got them on thanks for the advise they look great! Seem to be some real high quality sliders
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
