Proton Flushmount Turn Signals - Triumph675.Net Forums
Old 11-17-09, 09:22   #1
Smile Proton Flushmount Turn Signals
Here’s something a little different for your Triumph – Proton flushmount turn signals. These high-quality CNC-machined lenses fit into your OEM bodywork with no gaps, no cutting and no free play. What’s really neat about these is that it’s possible to set how they blink: from standard flash, to fade in/fade out and there’s also a strobe capability. This can be done without a separate load balancer or flash controller, all you have to do is wire it up with the included clear instructions provided and you’re done.
Call TJ at 866.931.6644 ext 817 and ask him to send you a set or you can ask him via email – TJ at RIDERSDISCOUNT dot COM
Made from CNC-machined acrylic, each Proton turn signal’s circuitry is surrounded in a tough, well designed housing.
With 12 LEDs soldered on each circuit board, these are bright turn signals.
No need to play with any load balancers or install different turn signal relays – Proton flushmounts blink at the correct rate on their own.
OEM turn signal on the left, Proton flushmount on the right.
Take your 675 from this -
To this – these fit perfectly into the Triumph’s OEM bodywork with no cutting, soldering of fussing.
Old 11-17-09, 10:13   #2
olazyazz
could you PM me with a price?
Old 11-17-09, 10:54   #3
Cutter
PM price?
Old 11-17-09, 11:41   #4
GreezMunky
GreezMunky's Avatar
Same here too please PM Price
Old 11-17-09, 12:32   #5
tommitls
can you PM me with pricing?
Old 11-17-09, 12:35   #6
PM's sent
Old 11-17-09, 13:00   #7
nezoid
nezoid's Avatar
I knew I should stay away from here.. Can you send me a pm with price :) thanks.
Old 11-17-09, 13:09   #8
B.Wild
B.Wild's Avatar
PM please
Old 11-17-09, 13:35   #9
PM sent
Old 11-17-09, 13:58   #10
plazabrit
plazabrit's Avatar
can you pm me with the price
Tags
flushmounts, led flushmounts, proton flushmounts, proton turn signals
