Fork Oil Level - Triumph675.Net Forums
post #1 of 11 Old 05-08-09, 17:23 Thread Starter
Bikoman
Bikoman's Avatar
Fork Oil Level
I am about to replace the fork oil in my 2007 675. The manual says 72mm which seems to high too me. All my other bikes are as follows Aprilia with showas - 118mm, ZX6R with Showas - 115mm, heck even my Buell with showas is 118mm. What are other trackday rider/racers who are using the stock forks using for a level?
Thanks,
John
Bikoman is offline
post #2 of 11 Old 05-08-09, 18:49
d3m0
I did whatever the manual said.
This tool should make it a lot easier, as well: http://www.mxdeals.com/tool-level-oi...tech-race.html
I didn't have that at the time, unfortunately I had to use a turkey baster, lol :)
Make sure you pump the cylinder inside the fork until it gets so stiff that you can barely pump it anymore, then fill it to what it says in the manual.
Good luck!
d3m0 is offline
post #3 of 11 Old 05-08-09, 18:59
Vitabrew
Vitabrew's Avatar
Don't fill to 72mm. When I first swapped my fork oil I filled to that level as per the book and it was way too stiff. I was gradually lowering the level till I got to 110 and that felt good again so I stopped there.
FWIW I had my forks revalved by Thermosman this winter (aka Ohlins USA) and he filled it to 120mm. I've only been to the track twice since then but it feels better than ever, no doubt some of that due to the new parts but some may be due to the lower fluid level.
Vitabrew is offline
post #4 of 11 Old 05-08-09, 19:21 Thread Starter
Bikoman
Bikoman's Avatar
Thanks
For my level tool, I use a plastic tube marked with a sharpie at the level I need with my mity-vac providing suction, quick and easy.
Bikoman is offline
post #5 of 11 Old 05-09-09, 21:48
Syks7
Syks7's Avatar
Send a message via MSN to Syks7
110 is what I was told by Dave Moss, so I'm pretty sure thats whats in there.
It requires and unusual mind to undertake an analysis of the obvious. WSMC #racing career on hold for the year so I can focus on my funding via my actual career.
Syks7 is offline
post #6 of 11 Old 05-10-09, 02:19
canyondancer
Way back in 06 Thermosman did my forks and he said the same thing. Factory recommendation is too high. Don't know how much oil he put in....but Thermosman is a genius.
canyondancer is offline
post #7 of 11 Old 05-10-09, 02:22
zangman
zangman's Avatar
One more recommendation. When I do the oil I don't go by height. I actually put the 495cc in it. I also measured what came out and it wasn't even close. Just an idea.
John
2008 GSXR600 "The Darkside"
Transmitted on 100% recycled electrons!
zangman is offline
post #8 of 11 Old 05-10-09, 21:41
Vitabrew
Vitabrew's Avatar
Some fluid can get trapped in the fork when you drain it and so if you add 495cc you will end up overfilling it. A fluid level tool can be picked up for $30 but a simple ruler and flashlight allows you to accurately measure the level too.
Vitabrew is offline
post #9 of 11 Old 05-11-09, 04:36
mervtheswerve
What weight oil do you guys use for track riding only.
using maxima products but would appreciate your recommendation and specs also.
currently using standard forks
"i thiught i had a handle on life..... but it fell off"
mervtheswerve is offline
post #10 of 11 Old 05-11-09, 22:09
Vitabrew
Vitabrew's Avatar
5w oil
Vitabrew is offline
