An oft-debated subject, I decided to do some EXUP testing today. I've done it in the past, but wanted to re-visit my findings to confirm them. So I present to you two graphs. The bike in question belongs to a forum member. It is all stock except a TOR muffler. I plugged in my new replacement ECU, which among a dizzying array of options, lets me choose the EXUP opening. (Tuneboy also allows you to mess with this, but this bike did not have a Tuneboy flashload in the stock ECU)
Graph #1- 40% throttle, 15% eddy load. Run 40 is the stock EXUP opening curve, run 42 is the EXUP opened 100% all the time. I was trying to be at 40% throttle by 2k rpm, and pretty much succeeded in hitting the marks.
Graph #2- 100% throttle by 2k rpm, 0% eddy load. Run 36 is the stock EXUP opening curve, run 38 is the EXUP 100% open all the time. Yes, there are two curves there.
I will let you draw your own conclusions. The only difference I could tell was the bike was noticeably quieter at lower rpm's with the stock EXUP curve programmed in.
