Replacing indicator on Street Triple - how? - Triumph675.Net Forums
post #1 of 2 Old 03-28-09, 14:09 Thread Starter
Sculler
Hi all,
My first post, but I've been reading the forum for a little while since getting my Street Triple a couple of months ago.
Anyway, I have a little problem - I need to replace a front indicator, and having collected the new one from the shop, am having some problems working out how to do it...
The wire runs out the back of the plastic fairing which covers the side of the radiator and then just disappears into a tight hole up underneath the tank. I've hinged up the tank, but there is a big plastic lump under there (where the fuses, ECU etc are attached), where the wire must go, but I have no idea how to get underneath to unplug the bust indicator and how to feed the wire for the new one through.
Any ideas anyone?! All comments gratefully received
Cheers,
Sculler
Sculler is offline
post #2 of 2 Old 04-08-09, 15:55
corpsedub
corpsedub's Avatar
Originally Posted by Sculler View Post
Hi all,
Cheers,
Sculler
unscrew the alen bolt that holds the signal on the body. then using a small philips head, unsrew the small screw at the end of the clear housing and pop the light fixture from the housing. you can then remove the spade connectors from the fixture and pop a new one on.
corpsedub is offline
