URL:s to Tuneboy and PCIII tunes for 675 - Page 3 - Triumph675.Net Forums
post #21 of 276 Old 04-24-08, 20:34 Thread Starter
roffe_s
roffe_s's Avatar
Originally Posted by ggillies View Post
GRRRRR.... This tune
Arrow full system
Wayne M have a dyno tune for this setup that get rid of the popping at decel. Dyno chart and link to the map can be found via this post: http://www.triumph675.net/forum/showpost.php?p=250458&postcount=18
Seems to be for a Street Triple??? I tried loading it and got an error message telling me it was the wrong ECU type???...
Hi Ggilles. Yep - that tune is for the str3 so no luck for us Daytona nerds using that map.
roffe_s is offline
post #22 of 276 Old 04-26-08, 03:37
AZ675
AZ675's Avatar
Whats a good map for the 675 with full arrow system? I just received my Tuneboy and awaiting key info. Any info would be appreciated? Im currently running the Triumph full arrow map. Thanks! AZ675
AZ675 is offline
post #23 of 276 Old 04-26-08, 04:58
Devilfish
Devilfish's Avatar
Send a message via AIM to Devilfish Send a message via Skype™ to Devilfish
^^^ Uhhh, the Full Arrow Exhaust Tune from Tuneboy, of course...
By the way, anybody here notice the change in Tunes??? The standard 675 Tune used to be called "20108" but now up on the Tuneboy site (and included with the latest version software) the standard 675 Tune is called "20203"... The Aftermarket Exhaust tune has also changed from "20109" to "20204". Does anybody know what has changed about them?
R.I.P.
Daytona 675
June 3, 2006 - June 27, 2010
Devilfish is offline
post #24 of 276 Old 04-26-08, 06:07 Thread Starter
roffe_s
roffe_s's Avatar
Originally Posted by AZ675 View Post
Whats a good map for the 675 with full arrow system? ...
There are a couple of Arrow maps tweaked by users on this site, unfortunately no one shared here yet. I would try the PCIII - map and compare that to the standard Triumph Arrow map.
Originally Posted by Devilfish View Post
...By the way, anybody here notice the change in Tunes??? The standard 675 Tune used to be called "20108" but now up on the Tuneboy site (and included with the latest version software) the standard 675 Tune is called "20203"...
They were announced during last autumn and I had a breif look to spot the changes. I believe I didnt find any changes in the tables, so the upgrade must be related to other functions...
roffe_s is offline
post #25 of 276 Old 04-26-08, 17:13
AZ675
AZ675's Avatar
roffe, thanks a bunch! Do I just search on here for the PCIII map? Sorry, Im new to the Tuneboy and this site. Thanks! AZ675
AZ675 is offline
post #26 of 276 Old 04-27-08, 03:06 Thread Starter
roffe_s
roffe_s's Avatar
Hi AZ, In the first post, there is a link to powercommander.com with all the PCIII tunes for the 675 and in post 2 and 3 there is a "how-to". The PCIII You would like for an Arrow full system is http://www.powercommander.com/downlo...s/m515-003.exe and use the 20110 as base map.
Good luck!
roffe_s is offline
post #27 of 276 Old 05-07-08, 16:52
PragB
PragB's Avatar
Send a message via AIM to PragB
Already disconnected the O2 sensor, and am contemplating cutting out the section with the exup valve & cat... what would be the best map to run?? The Leo Vince full system map?? I don't want to have to change the plugs so I don't think I should do the Arrow?? Would I have to with the Leo full map?? Any thoughts??
PragB is offline
post #28 of 276 Old 05-07-08, 17:07 Thread Starter
roffe_s
roffe_s's Avatar
Wow PragB, You relly are bitten by the mod bug eh?. You are doing a impressive work on Your bike!
I wouldnt worry too much about the small spec difference between the plugs. Actually, I've got some NGK iridium of the Arrow specs lying around until its time to make the big service for me, just because of the ign advance and the earlier EXUP opening in my map.
However, You still got more narrow hedders than the full systems. I would perhaps start with the leaner of the two maps and stick with that. Maybe go for the Arrow map and add a couple of degrees ign advance above 10k? Hordboy have done a ton of these kind of testings, and I believe he went with the Arrow tune.
Good luck with Your work!
roffe_s is offline
post #29 of 276 Old 05-07-08, 18:44
PragB
PragB's Avatar
Originally Posted by roffe_s View Post
However, You still got more narrow hedders than the full systems. I would perhaps start with the leaner of the two maps and stick with that. Maybe go for the Arrow map and add a couple of degrees ign advance above 10k? Hordboy have done a ton of these kind of testings, and I believe he went with the Arrow tune. Good luck with Your work!
Thanks for the advice I will go that route, however I need assistance...
"Maybe go for the Arrow map and add a couple of degrees ign advance above 10k?"
I am not sure how to do that
PragB is offline
post #30 of 276 Old 05-07-08, 22:54
CrazyCam
CrazyCam's Avatar
STREET TRIPLE:
A general description of standard maps at the Tuneboy site for this bike can be found at http://www.triumph675.net/forum/showpost.php?p=250461&postcount=38
Compareable dyno charts for standard vs arrow may be found at: http://www.triumph675.net/forum/showpost.php?p=250484&postcount=12
I hope this will make things a little bit easier for new TB users, finding their way to the tunes.
OK, I've bought the TuneBoy, got the key to make it work, now, the tune described for a stock standard Street Triple, which looks near as good as the Arrow.....where do I find it, please.
Also, are there any quirks to it, like having to use 95/98 octane fuel?
CrazyCam is offline
