30-second bar end removal - Triumph675.Net Forums
Old 12-07-07, 11:32   #1
daleCarlsbad
daleCarlsbad's Avatar
Default 30-second bar end removal
Removing the bar ends without damaging the smooth finish is very easy to do with the right tools and a bit of know how. The following is for the throttle side.
1) First remove the throttle to expose the two retainer clip holes and pin hole (located on the bottom side.
2) I used an old bicycle grip cut down to fit over the end piece which allows you to hold the piece while you unscrew the 3-mm Allen bolt.
3) Once the end piece is removed, you will need to use the small screw driver to push the retaining pin down. If you don’t do this the bar end assembly is NOT going to come out.
4) Next screw the end piece back in part way to give you some thing to pull on.
5) Push in the retainer clips on both sides, and pull on the end piece.
6) That’s all there is to it. No galling the end piece with channel-locks, or spaying lubricant into the handle bar.
Old 12-07-07, 12:22   #2
warpedreality
|-_-|
warpedreality's Avatar
Good job bro! Thanks :2tu 8)
Old 12-07-07, 12:48   #3
karamozov
karamozov's Avatar
Nice post! Good pics, good explanations.
Thanks for taking the time.
Old 12-07-07, 14:27   #4
Budo
I am a Fcking Fantastical Dancer
Forgive me for being retarded, but what the hell is that long bar inside the clip on supposed to do? Other than hold on to the bar end...?
TACTAA
The bad thing about riding a motorcycle is you cant hear the phone ring.
The good thing about riding a motorcycle is you cant hear the phone ring.
- Scott P.
Old 12-07-07, 14:51   #5
daleCarlsbad
I think it is to dampen vibration?
Old 12-07-07, 17:01   #6
firestarter
firestarter's Avatar
it's for reducing vibration through the bars similar to a bar snake which does the same job hope this helps
Old 12-07-07, 17:43   #7
MIS3
MIS3's Avatar
That's a good post. I had to change mine when I jacked one up from a track crash. Wish I woulda had this info then. I had no idea that damping bar was in there, took me forever to figure it out...I thought it was there to reinforce the bar, since the clip on didn't get bent at all.
Toledo, Ohio
Old 12-07-07, 18:27   #8
Red 675
Red 675's Avatar
It may take 30 seconds to perform, but it took me 5 minutes to read. LOL!!
Thanks!
Michael
Bling Responsibly
Old 12-07-07, 22:00   #9
FastOF
FastOF's Avatar
Location: Western NC; Home of the roads you wish you had.
Send a message via AIM to FastOF
Anybody got a set of the bar inserts that they want to donate/loan for the purpose of getting Throttlemeister to make an application for the Daytona?
"Everybody's got to believe in something.
I believe I'll have another beer."
- W. C. Fields
Old 12-08-07, 04:00   #10
Devilfish
Devilfish's Avatar
Send a message via AIM to Devilfish Send a message via Skype™ to Devilfish
I have a question for you Dale...
What if you just want to replace the bar end piece with a new bar end piece, like a Rizoma or Skyking?
Do you simply undo the allen and it comes off, or do you have to push pins down too, to get it off? Or, do you have to go as far as you did in this disassembly?
R.I.P.
Daytona 675
June 3, 2006 - June 27, 2010
