Has anyone ever put in a switch to cut off their low beam?? I am also wondering if I could wire the low beam to the high beam switch and have them both come on at the same time?
I want to be able to turn the light off (and No, not while I'm driving on the street, for all the goody goodies).
I heard I could install a switch to the ground of the low beam and be able to accomplish this.
I wired both my headlights to turn on/off with the high beam switch. however, i converted both my projectors to low beam projectors, so no more high beam for me
ha if you just get another headlight, you can swap the low beam projector over with, i believe, zero modification. only difference is now you will need 2 H7 bulbs instead of H7/H9. i have HIDs, so i just bought new bulbs
i also used my stock projectors left over from my WRX -> TSX retrofit. bit better light output and cutoff.
Any one have the pics to show how they wired the low beam to the high beam switch?
I am good with wiring, I just don"t want to screw up and cut the wrong wire.
I am looking for a wiring diagram on the internet too, but it is hard to find. If I get some pics, I won't need the diagram. Thanks.
Since I have the twinlight driver, all I am going to do is run a switch inline with the orange wire from the twinlight before the box and run the up to either the handle bars or the infill panels. BTW, I have a waterproof 30A switch coming in. I am thinking about putting a fuse in line just in case.
Does anyone know where to get the right hand switch block with the original headlight on/off switch?
I’ll be keeping my light on, I have another use for the switch… :halo:
I'll be keeping my light on, I have another use for the switch… :halo:
I wired my halos to the low beam and both HID's to the high beam without incident. Ive had it like that for about 2 years now. No complaints whatsoever. On my way to work I passed a co-worker and fellow rider with only my halos on. He said he could see me quite a ways back with only the halos. I had a post here somewhere that showed how I wired everything. It was pretty pic intensive. Ill post the link if I can find it.
Left hand switch!
Not right… must be the madness taking over….
I keep an eye on EBay but no luck, might lean on my local dealer and see if the earlier speed triples or speed 4’s came with the option.
Or I’ll strip the standard one apart and see if I can get creative with the space inside.
You need a switch gear off an older Triumph that had the capability to turn the lights off. Not sure what you guys may have had to be able to do that. In the UK we have the original Daytona 1200s and Tiger switches.
It hasn't been legal to shut off a motorcycle headlight in the USA since the 70s. So no Triumph of the modern ones would have ever had this option here in the states. Its going to have to be imported.
I installed one of Tony's first generation kits quite a while ago. A simple toggle switch wired into the ground side of both low and high beam allows me to shut both on or off anytime - as long as the ignition is on.
Both switches were incorporated into an old plastic 35mm film canister, completely waterproof when the cap is snapped on, and mounted for easy reach with the thumb. The forward switch controls the headlights...
and the rearward controls running lights built into the rear turnsignals.
The switches were installed into a plastic Rx pill container...
and slipped into the black film canister.
I've got more photos but never bothered to post them.
For the time being, until I can figure out a switch setup (what kind, where it should go, etc) I just unscrewed the black plastic cup so I can unplug the low beam if I need to. Like if the stator or regulator fails (again) I want to be able to conserve as much power as possible.
I just did the FH008 rectifier mod, but I still don't trust the charging system.
According to the florida law: "Any person who operates a motorcycle on the public streets shall, while so engaged, have the headlight or headlights of the motorcycle turned on."
Bummer. I didn't think you had to have a headlight on during the day. Ill be more mindful of that from now on so I don't get harassed.
Here is my new and improved idea. I am going to wire the low beam to the OEM high beam switch. then rewire the high beam to function only with the flash to pass trigger. I want it to look as clean as possible. I will start on this this weekend.
I do not ever use my high beam. For me, it is not a problem. I would just rather have it then not. That is why I am not doing away with that function.
I guess the internals of the pass trigger could be changed to mimic a click on clock off type function. Sort of like a click pen.
This was my initial idea. However, I was going to drill a hole behind the flash lever, and try to mount a push on/off switch inside the black casing, with the push part sticking out so the flash lever would push it.
With a little modification, I think that may fit inside the housing. Relative to what I have see, there isn't mush in the housing. Especially if we remove the metal "bracket" that holds the wires separate from the switch.
Where did you buy this? I looked at the K&S website and they don't sell directly to the public. Are there 9 wires to the connector (hard to tell from photo)? It looks like you can have just the position lights on, is that right? Thanks, Eric
