If you are referring to the connector, I can help you as I recently installed a PCV in my 2014 and took the attached picture. Also attached are the installation instructions which indicates the connector in Fig.G on page 5. You have to raise up the front of the tank to access it. Releasing the connector is tricky. You would need to trace this wire to locate the sensor itself.
I'm not familiar with the Rapidbike EVO, but from your pictures, I would wonder whether you were sent the proper wiring harness for the 13+ Daytona. The PVC matched all of the connectors exactly and was truly plug-n-play.
I am real eager to hear how the Rapidbike works for you. I have been tuning with an LM2 and I am not finding as much joy as I would like, honestly I am spending a ridicules amount of time on it and I am considering going Evo or Race.
I've fitted the Rapid Bike EVO with no dramas. Just make sure you've got the right plug. Everything was plug and play when I did it, despite it being a bit annoying to get all the injector plugs connected.
It might be the wrong (RB) wiring harness by the sounds of it. I haven't got mine installed so will go grab it from the garage.
Pretty sure the CPS connectors on mine were white/clearish plugs though (on the bike).
Quick update: TPS should be the three pin. Crank sensor (CPS) two-pin. Gear position sensor three-pin. So your loom looks right.
The detailed instructions they give should tell you the plugs you're looking for and also the wire colour combo.
I've got an early 2013 (new Gen model) and like I said had no issues. Some of the connections - CPS and O2 sensor - were a right pain to get to though. CPS should be between your ABS brake lines from memory, right down low.
Pretty sure this is the Crank S. point you need. The yellowy clear plug.
There's also a three pin deep in under there that is probably the other one you're looking for. I'm just assuming here as I've got the tank up for another issue and took this quick pics and couldn't find my EVO instructions to confirm by wire colours.
See this is where I'm confused, on the rapidbike istructions it's showing the clear connection as the crank sensor just like your showing me, but if you look at the PCV instructions it shows the 6 pin black connector as the crank sensor which matches my bike.... that clear connector on my bike links to the rear ABS and the other black one next to it is the quick shifter..
Although the PCV uses the six-pin connector, the Bazzaz and it appears also the Rapidbike uses two other connectors that are even harder to reach (easier if you pull the crankcase ventilation hose out of the way). The following link is a forum disscussion by one of your countrymen regarding connecting the Bazzaz to those connectors. If you start reading from Post #27, you may find this guy's approach helpful:
Ahh, thank you Avanti! that's sorted that problem out.. :thumbup:
As for the gear sensor, I was missing a separate loom that converts the 3 pin into 4. They are sending it out this week. Apparently some are 3 pin and some are 4... Mine happens to be 4.
Just had a quick look and it's all one piece, with no separate loom/connection. I haven't had it connected in quite a while as no one around here will touch them for tuning unfortunately.
i think i have the same problem like yours.can not found the crankshaft sensor position plug two pins in white as introduction with rapibike evo,only the black-six-pin next to injection sensor.so i’m wonder how did you solve this problem,can you share it!
i think i have the same problem like yours.can not found the crankshaft sensor position plug two pins in white as introduction with rapibike evo,only the black-six-pin next to injection sensor.so i'm wonder how did you solve this problem,can you share it!
hi torana9x! i think i have a same problem too. my 675rx still can not found crankshaft sensor with two pin in white as introduction said.only found 6–pin-black plug beside the injection sensor.how about you after all, did you solved it?
Hello torana9x, I have the same problem!!!! but I didnt understand how you solved......do you get other cable to connect 2 pin crank sensor?
