I am selling one or both of my Triumph Daytona 675 race/ track bikes. Both are track only bikes and cannot ever be converted back to street bikes.
2006 Triumph Daytona 675, no title will provide bill of sale. Was on an out of state title that was never transferred.
6729 Miles.
Optimal race fairings
carbon fiber front fender
Fully safety wired, meets CMRA requirements
Custom full exhaust and dyno tuned ECU, 116 HP at the rear wheel
Elka triple clicker rear shock with 625 lb rear spring. Linear linkage plates
Valved front forks with .95 springs and Race Tech top out springs to add travel. One TD on fork oil
Stock radial calipers and MC with Vesrah RJL pads
GB racing engine covers
GPR steering damper
Manual idle
Yoyodine adjustable quick throttle ( have different sized cams for throttle tube)
Apex offset triple clamps to reduce trail improve corner stability
STM slipper clutch ( will include STM clutch tool as well)
Sidestand is installed but safety switch has already been by-passed for easy removal.
Brand new battery
Tank grip pads
Keyless ignition
Brake lever guard
All this bike needs is fresh tires and gas. The tires that are on it are over a year old and although they have enough tread, I would not use them on the track. Bike is runs great, has amazing handling, and is very fast. $4250
2009 Daytona 675
Was low sided on right side. Engine covers and fairing scuffed. Tank dented, no oil leaks
Mostly stock, bought this to replace my 06 as the 09 should be able to make more power, plus it has high and low speed compression adjustment on the suspension.
Two Brothers slip on, EXUP by pass,ECU flashed
Bike was salvaged and came from COPARTs. No title, but will include bill of sale and provide paperwork from previous buyer.
Odometer shows 1773 miles
Cluster works but lens has cracks
Fairings are secure but some of the mounting brackets need to be straightened.
Brand new battery
Bike starts and runs great. Needs fresh tires but is otherwise ready to ride. It could use some small attention to detail on the fairing mounts and wiring (zip ties and such, all wiring is in good condition and works ).$3500
Buy both and I will throw in a small folding utility trailer, stands, one pit but TRS, one wheel chock, one set of warmers, and some spare parts (dented tank, sprocket carrier, etc....)
The 06 has the yellow number plates front and rear, the 09 has the red rear wheel
6729 Miles.
GPR steering damper
Manual idle
Brand new battery
Tank grip pads
Keyless ignition
Brake lever guard
2009 Daytona 675
Brand new battery
