I removed the triumph carbon fiber tank pad from my 675r only to find it scratched all the way down the sides of the pad. I put new tech spec tank grips on it and didnt cover all the scratches.
Diagnosed the ticking sound I was experiencing as a cracked exhaust header at the weld between the cyl 1/cyl 2 crossover tube. Seems that this is a somewhat common defect on some bikes X(
Check around 30 secs in for a decent example of the ticking. The brief white smoke is just some oil burning off that dripped onto the headers during maintenance.
Spiffed her up, ready for a bike event at the Nürburgring next weekend. Got all my pieces on from the guys over at Carbon4u. They do damn good work, and the customer service is top notch.
I just called "Mr. Watson" yesterday and mine should be shipped next week. That makes 10 weeks. Better order today! I know they are worth it, though! I can't wait to get them!
changed oil and installed 1050 tube. Where do you all have your throttle adjustment set with the 1050 tube? It feels weird but i'm not real sure which way to go with it?
manual CCT, air filter, and checking the spark splugs when the air filter and crank case gasket comes in
took my bike for a spin with no fairings on because i was impatient after uploading daves tune and holy shit... the bike never lifted up before in first and scared the shit out of me. It pulls like a beast.
Still you have 30 days to register a newly bought vehicle in most states. As long as you can show when the vehicle was bought.. Like I got pulled over all the time in kansas and missouri in the first week of owning my bike, all I did was show the cops my title of when I bought it and they let me move on.
I refilled my D675's steering damper. These have a reputation for being crap but it's only because over time they seep a little even with perfect seals and then they get air in them, causing poor damping and a squishy feel. When I got mine off it was half empty, and pushing it through it's stroke you could feel it hit air pockets.
The trick to filling these is to get all the air out of them. Most people try to use a small syringe but it's impossible to get all the air out that way, so here's a better way. A funnel hooked up to a clear plastic tube. Then you just keep pumping until all the air gets out and you don't see any more bubbles. Fork oil is the most common fluid, and it has the benefit of being available in many weights. Probably 15W or 20W is the most common but I went up to 30W for more damping ability. Got it back in, went for a ride and the damper felt much better. It actually damps like I would expect it to now.
Zaph, I need to do this on mine. I can figure how to drain it I'm sure. What is the proper procedure for filling it? Just hook up the clear tube to a funnel and fill the funnel then push the plunger on the damper back and forth until no more bubbles come out?
Spent a good 3/4 hours trying to get the damn parking light bulb out of the headlight housing because it fell out when I was trying to fix some wiring to make the parking lights into turn signals. Helpful hint to anyone who does this...say oh fuck!!! curse and then grab a coat hanger tape a small magnet to the end and be very very very patient when it doesn't come out till the sixth time. Fuck man :1banghead:
Then rode the shit out of her for a couple hours while doing the bazzaz afm self mapping since she hasn't been in one piece for three months. Watch out BOTM submitters...She's back with a vengeance.
Rode it for the first time, due to a small break in the weather. Put on my first 130 miles. Went well, and I enjoyed the ride, but I can't say I enjoyed it thoroughly. Keeping the tach below 6,000 rpm was hard!! :laugh:
Can't wait to get thru the break-in period.
Here's a few pics so you can get an idea what long damn winter it's been. :itsok:
I break-in all my motors on a dyno. In my eyes it's the only way. I know, I know, but I'm not willing to argue this point. I'm only telling you what I, and a ton of other people think including every pro racer on earth.
Balanced my rims to find the heavy spot, which wasn't at the valve stem on either rim, like most tire shops assume. Then put on a new set of Dunlop D211 slicks, yellow dot on the spot. Needed about 50 grams less weight than what a shop usually puts on.
Washed and waxed her today. First time riding the bike after I bought her. Feels way better and smoother than my r6. I'm keeping this bike forever. Sounds good even with a stock exhaust.
Related Threads
Triumph 675 Forums
1.2M posts
39.9K members
Since 2005
