2012 Daytona 675R,
With a 2012 ST3R Wiring Harness
Two issues. With the key and kill switch to the "on" position and the clutch pulled in, the starter button doesn't do anything. No noises or clicks, completely dead. Fuel pump primes as normal during initial start sequence.
If I hit the starter button while the fuel pump is priming, it turns over and idles normally, for about two to three seconds and then cuts out. I adjusted the idle up/down with the manual idle adjuster, no ISM, and no change. Just idled higher or lower for a couple seconds and cut out.
I checked the relays and fuses, all are conducting/working properly. This was my initial thought. Fuel line is not pinched or anything, at about half a tank of gas. I have a service manual, studying the wiring for any common grounds etc.
Any ideas on the idle cut? I have replicated the problem numerous times without any change. TuneECU is the next step to go through everything. Haven't tested the battery either, but it starts just fine in the given scenario above.
Any ideas will be greatly appreciated. Thanks.
Adam
Adam
