Hey all.
I'm using TuneECU for Android (app v2.8, android v7.0) wired to my 2006 Daytona (not bt)
I updated the map and tried to reset TPS.
Can someone confirm I was doing it correctly and that it works on android?
Connected with ignition, engine off.
On the Adjustments Screen: ECU-> Test & Adjustments -> Adjustments -> Reset Adaptation -> Run.
A pop-up appears saying "Adaptation Reset Complete" with "ok" button.
I fire up the engine and then hit "ok"
and I wait...
I waited 15 minutes and nothing happened.
When Ive done it on a PC, the Green & Blue arrows appeared and eventually the Green dot appeared indicating the process is complete.
However, on the android app the Green & Blue arrows never appeared.
In the TuneECU Android page (http://www.tuneecu.com/TuneECU_En/android.html) they have a screen shot of the Diagnostics page showing the arrows (see below).
Can someone confirm this worked for them?
Did I just not wait long enough even after 15 minutes?
Bonus question: Why is Rest Adaptation only available from the Adjustments page, but the status is only displayed on the Diagnostics page? (poor ux!).
Thanks!
Chris
and I wait...
Thanks!
Chris
