I'm pretty much at my wits end so I'm throwing this last chance hail mary in hopes somebody has dealt with a similar issue:
Bike: 2014 Daytona 675 w/ race ECU and harness, Bazzaz Z Fi TC.
Issue: Gear position indicator is completely skipping 3rd gear whenever I run through the gears (1 N 2 4 5 6). When I'm in 5th the display reads 6th.
Attempted Interventions: I replaced the Gear Position Sensor. After I installed the new sensor I manually rotated the dial. The display STILL skipped 3rd gear. I'd suspect a faulty replacement if it didn't skip 3rd gear just like the one I replaced. I disconnected the ECU and the battery in hopes it would reset or recalibrate whatever it is that's causing the glitch. I should also note that the gear position initiator on my Bazzaz software also does not indicate the correct gear either. It just stays in neutral regardless.
I'm stumped and beyond frustrated (also troubleshooting an inoperable quick shifter)...hopefully somebody can point me in the right direction before I'm forced to take her to the shop.
