Hey guys,
Was able to take my bike out after a month being in the shop. Had crashed back in December and a road reflector sheared off my left stator case. I had to replace the flywheel, stator, and fuel pump. Today I went on an all day ride with about 8 stops. Randomly and three times today.. the bike would bog down after 6k-7k rpm in any gear and wouldn't pull. It sounded as if you're going up a steep hill in too high of a gear or if you've ridden dirt bikes, that sound/feel when the 2-stroke engine was still cold bwaaahhhhwahhhh. Twice, I had to shut the bike down and when I fired her up it was fine. The last time it started maybe 5 minutes into the ride home and went away 2-3 miles later on the freeway.
At first I thought maybe a weird sensor thing.. sometimes my speedometer gets 1st and 2nd mixed up.. the digital will read 2nd when I'm really in first. I had started the bike up the first time this problem occurred while the speedo read 2nd but I was in 1st, and I thought maybe it messed with the computer that controls something related to the fuel.. but I don't know bikes enough (yet). Has this happened to any one before? I plan on taking it to the mechanic that installed the fuel pump soon but I'd like to go in with more knowledge and so I can better explain the problem.. I'm stationed in Okinawa so there's a slight language barrier. Thanks in advance!
