Hi Guys
I recently bought a 2006 Daytona 675 and after some stripping yesterday, discovered there has been a catastrophic failure inside the head the past. The other problem is that three of the inlet valves are letting oil past the guides. The manual states there is no way of replacing guides and the only solution is to replace the cylinder head :|
I thus need to find another cylinder head.
I have done a fair bit of googling, and it seems the 2006 -2008 street triple and Daytona heads are the same, excluding the cams. Is this information correct? I have found a second hand street triple 2008 head and would like to purchase it, but would like confirmation as to whether the heads are in fact a straight swap, I will simply use the Daytona cams
Thanks!
Thanks!
