So i've actually got the pipe coming from the REAR of the reservoir going to that little nipple. Is that wrong? If so where does the rear pipe connect to?
Thanks for your help!
You might have figured this out but that's wrong. The correct routing is front hose (overflow) goes behind the reservoir, through the sprocket cover and behind the metal pipe to the ground. The rear hose goes straight forward to the radiator.
I'm in the same process of remounting this and if you google pics of the sprocket cover you can see this. Also, the rear hose has a metal clamp on it. At least mine does. This is to make sure it stays on the radiator nipple.
Hope this helps
