I'm trying to remove the front cowl to get to the parking lamp and headlight housings to replace with LED'S. I know I need to remove the side fairings and then the front cowl and head bowls slide forward? I'm hung up on the fairing removal because I can't get those PITA screws to come loose. What is the trick? I have read that these are a problem and have tried to manipulate with a small flathead at the base of screw, squeeze screw while turning, etc but can't get them out.
What is the trick?
Thanks in advance!
What is the trick?
Thanks in advance!
