So if you have a Standard Street Triple, you already know the front fork sucks. I've got the solution for you.
These fork tubes were off a 2012 Street Triple R. They will fit any year of Street Triple. I'm giving away a pair of Daytona front Calipers with them so you basically have the complete conversion. Please note that the caliper have some cosmetic scratches, they still operate perfectly and you should also think about replacing the pads. I'm asking 450 USD for the fork tubes and both daytona calipers. Note that the forks were serviced at the start of this season.
If you have a 2013+ ABS model, you will need Brake lines, which I happen to have also available. I also have a Daytona front Master Cylinder. I will do the brake lines (2) along with Master Cylinder for 150 USD. 3D printed reservoir bracket since the daytona bracket will not fit.
