On a 2014 Daytona w/ABS, if you want to put in a race ECU and harness the ABS harness disables the function of the ABS.
With that said shouldn't you just get an ECU with a non ABS harness and remove the ABS system all together? Or is there some reason you would need to retain the disabled ABS system?
Thanks.
Thanks.
