Hi guys, today as I was about to head to work my 2012 Triunph Daytona 675 turned off when I gave it gas on neutral. I turned her back on but kept doing the same. Everything seems normal when it's on bit it's just when I pull on the throttle that it turns off. Everything was working just fine before. It was sitting for about 2-3 weeks so idk if it's possible that the gas went bad. Any help would be greatly appreciated. Thanks
If everything is unchanged since your last ride and the last ride was fine, I would bet a bad dose of fuel or a blocked up fuel filter. Does your dash display a CEL.
Thank you for your reply. My dash does not display anything while it's on. Everything is perfectly normal until I pull on the throttle. I'm going to try and remove the fuel and see if that works. Would you happen to know where I can locate the fuel filter?
That's strange. I've had bikes sitting for much longer than that (2-3 months) with no problems. Though I'm not saying it's OK to do that, I'm just saying that 2-3 weeks of sitting should not make your gas go bad enough to shut off your bike, ESPECIALLY if it's fuel injected.
Unfortunately, I don't know what could be the cause. Does it idle fine too?
Thats exactly what I was thinking too, I'm guessing something might be clogged or something. It does idle normal,
