So here it is. I bought this 2008 D675 approx. 8 Months ago which was already partially setup as a track bike. The bike was bone stock except for a Remus slip on and Race Glass.
Mods started after her first outing on track. This was prompted by very poor OEM suspension that made my day on track challenging. I ran off track twice and experienced a few decent tank slappers.
Anyway, 8 Months later and this is her now. Plenty more photos to come after the mod list.
Suspension:
- OEM Forks re-valved with Racetech Gold valves and Wilbers 10.5 Fork Springs.
- OEM Rear Shock also re-valved with Racetech Gold valves and fitted with an Ohlins 13.5kg spring
Deleted OEM Gear:
- Removed Intake Flapper
- Removed SAI (Rerouted crank case breather to Reed Valves)
- Removed O2 Sensor
- Removed EXUP Valve
- Removed Idle Stepper Motor
- Removed OEM Rad Overflow Bottle
- Removed ignition (replaced with missile switch)
- Removed Heat Exchanger
- Removed left switch block
Intake and ECU:
- BMC Filter
- 09 D675 Velocity Stacks
- Balanced TB's with TuneECU
- Uploaded Arrow Full System Map
- Installed Manual Idle Control
Engine:
Stock
Exhaust:
Custom built low mount system using OEM Headers. System uses a cone engineering merge collector to 2" pipe leading to a SP Engineering muffler.
Brakes:
- Yamaha R6 front calipers
- R6 Braided lines
- Brembo RCS19 Radial Master Cylinder
- OEM Rotors
- SBS Sintered Pads
- OEM Rear brake
Other Mods:
- Renthal Sprockets
- DID 520 ERV3 Chain
- Lightech Chain Adjusters
- Axle Armour sliders on the rear and home made sliders up front
- GB Racing case protectors and frame sliders
- Alien Motion Li Battery
- Motion Pro Rad overflow bottle
- Attack Rearsets
- HM Plus Quickshifter
- Cox Radiator Guard
- Renthal grips
- Samco Sport hoses
- JHS Oil Cooler
- Monkey Bones front brake guard
- HM GPS Dash
- Hyperpro top mount steering damper
- Motoholders Fairing Stay
- SES Lock Stop Protector
- NJCustoms Tank Sliders (still in the post)
The bike hasn't been on track since all of these bulk mods have been done but am looking forward to it. I am new to racing and will be racing this bike next season. Am making the transition from track days to racing.
I would like to thank everyone on this forum. During the build this forum has been my number one resource for information, all of which has made this build easy and enjoyable.
Thanks for reading.
Regards,
LG
Suspension:
Deleted OEM Gear:
- Removed O2 Sensor
Intake and ECU:
- BMC Filter
Engine:
Stock
Exhaust:
Brakes:
- R6 Braided lines
- OEM Rotors
- SBS Sintered Pads
- OEM Rear brake
Other Mods:
- Renthal Sprockets
- Attack Rearsets
- Renthal grips
- Samco Sport hoses
- JHS Oil Cooler
- HM GPS Dash
Thanks for reading.
Regards,
LG
