Need help, replaced clutch cover gasket but stuck
653 views 2 replies 2 participants last post by  mpusch
Hey guys,
need urgent help here
I noticed a leak on my clutch cover, so i decided to replace the gasket today. got the oem gasket from the dealer, and took the clutch cover off.
everything was going smoothly, until i had to put the cover back on.
i can't figure out how to position the clutch release mechanism with the clutch lifter rod. when i do get the clutch release mechanism aligned, the clutch cable does not have any slack.
also when installing the new gasket, is it necessary to use some sort of gasket spray or silicon ?
thanks
