I've just collected my Daytona 675 today, which unfortunately is stolen recovered!
Spotted this plug under the seat - any idea what it's for? I'm thinking maybe alarm? There's also some bullet connectors which aren't plugged into anything near it
Do you have aftermarket blinkers or tail light? I'd start there.
If that's not it check them for voltage. Then turn the bike on and see if voltage changes.
If voltage is constantly on check if there's anything hard wired to the battery.
If nothing's hard wired to battery pull one fuse at a time until voltage goes to 0.
These will work only if you have power on them.
If there's no voltage with the bike off but then yes when the Bike is on someone wired something into your existing circuits, which is actually safer for the bike so that would be ideal
Does the green wire come out of a harness or just a stand alone wire? It's definitely not a factory connector. Where does it go to?
