parting my '09 daytona race bike out and emptying my garage as well. stuff will be added as i dig them out of my garage. located in salt lake city. shipping to continental united states only. paypal payment. reasonable offers considered. combining shipping a plus on smaller items.
- '06-'08 style optima race body work with supersport tail. never been down. cracking on bottom of belly pan. old beat up triumph aero screen. zeus fasteners. rattle can paint job. $300 (prefer pick-up, but willing to ship if really need be).
http://i89.photobucket.com/albums/k213/nohero55/race1_zpsz4mbrtzr.jpg
http://i89.photobucket.com/albums/k213/nohero55/race2_zpsv9zxlwx5.jpg
http://i89.photobucket.com/albums/k213/nohero55/race3_zps538wnhly.jpg
http://i89.photobucket.com/albums/k213/nohero55/race4_zpsva8yrelu.jpg
http://i89.photobucket.com/albums/k213/nohero55/race5_zpsi2uqulxg.jpg
http://i89.photobucket.com/albums/k213/nohero55/race6_zpsq9u5hgqf.jpg
'09 daytona frame. broken steering stop. scratches all over. $200 (prefer pick-up)
http://i89.photobucket.com/albums/k213/nohero55/frame1_zpso3euclk8.jpg
http://i89.photobucket.com/albums/k213/nohero55/frame2_zpszyw85rnj.jpg
'11 daytona swing arm. year they were slightly longer than older ones. triumph carbon heel protectors. scratches all over. $80
http://i89.photobucket.com/albums/k213/nohero55/swing1_zpsrqhlth0f.jpg
http://i89.photobucket.com/albums/k213/nohero55/swing2_zpsaebulawf.jpg
'09 daytona stock header and midpipe. $100
http://i89.photobucket.com/albums/k213/nohero55/header1_zpsn0z0ls53.jpg
- '09-'12 triumph arrow screen. light scratches on upper part. really hard to capture with a camera. priced accordingly. $70
http://i89.photobucket.com/albums/k213/nohero55/aero01_zpsuyuk7b2y.jpg
http://i89.photobucket.com/albums/k213/nohero55/aero02_zpsegeux7ww.jpg
- '06-'12 daytona rear fender $40
http://i89.photobucket.com/albums/k213/nohero55/fender01_zpskauv4n9c.jpg
- sato racing helmet lock for '06-'12 daytonas. basically new. installed once, removed a day later when i sold the bike. $60
http://i89.photobucket.com/albums/k213/nohero55/satohelmet_zpstwo9vddt.jpg
SOLD:
- '09 daytona forks with ohlins fgk 209 nix 30mm cartridges. 1.0kg springs. only four weekends on them since rebuild. scratches on fork bottoms and on one of the top hats. $900 SOLD
- ohlins ttx36 shock with hydraulic preload adjuster. 21040-41/115 spring. only four weekends on it since rebuild. $900 SOLD
- '09 daytona front and rear wheels with stock rotors and rear sprocket carrier. scratches from tire mounting and dismounting. $500. SOLD
- brembo rcs 19 master cylinder. rash on end of lever. no brake switch. $250 SOLD
- motoholders race fairing stay. '06-'12. basically brand new. only used one weekend. $130 SOLD
- attack rear sets. '06-'12. beat up, but functional. good for spare parts. $100 SOLD
sato racing spindle holder. '06-'12 $50 SOLD
triumph translogic quick shifter. pull type. $200 SOLD
jhs billet aluminum oil cooler $200 SOLD
ses steering stop $50 SOLD
'09 daytona nissin brake calipers, front brake lines, and good galfer hh pads. $100 SOLD
hyperpro oem mount steering damper. $150 SOLD
'07 daytona scorched yellow gas tank, carbon sliders, carbon tank pad, no name gas cap, fuel pump, and tech spec grips. deep scratches on top. no dents or leaks. $125 SOLD
woodcraft ignition eliminator. brand new never installed. just out of package. $60 SOLD
- '06-'12 triumph daytona arrow slip-on and modified subframe/battery tray. subframe lightened. arrow exhaust pipe (not can) shortened an inch and mounted to subframe closer. shoves the exhaust under the tail more. works with stock midpipe. plate hangers removed from silencer. beat up, but pretty straight. $200 SOLD
- attack racing '06-'12 rear sets. basically new. came off the street bike. couple marks on the foot pegs from use, but clean other wise. still in gp shift mode. comes with woodcraft return spring and pressure brake switch. everything you need to make the jump from stock. $410. SOLD
- '09 daytona radiator. no leaks. end tanks have some dents/scratches. lived behind a radiator guard. $90. SOLD
- '06-'12 triumph stator cover. black. a couple cosmetic scratches. $50 SOLD
- '06-'12 triumph stator cover. brand new. grey. comes with new gasket. $100 SOLD
- oz motorbike piega forged aluminum wheels with brembo supersport front rotors and braking rear rotor. two spots of rash on front wheel. otherwise fantastic condition. all rotors in great shape (never use the rear brake). used 47t 520 renthal sprocket included. $1700 (1200 for just rims; 500 for just brake rotors) SOLD
- triumph '06-'12 daytona gel seat. no rips or tears. just a couple marks from sitting in a box. $70 SOLD
- gb racing frame sliders. usable. i have a newer rh mushroom not pictured that will be included. $50. SOLD
- '06-'12 bmc street air filter. used. $30 SOLD
- triumph brake lever. long. just a small scrape on very end of lever. otherwise good. $75 SOLD
- renthal 50mm clip-ons. no bars. $80 SOLD
'09 rear brake caliper, bracket, line, and oem pads. $40 SOLD
'09 daytona stock triple clamps. scratches on top left. $50 SOLD
'09 throttle body assembly. $50 SOLD
'09 af sensor. $50 SOLD
'09 daytona ecu. tune ecu tuned. arrow slip-on map. sai and flapper disabled. pretty sure it still has the 3000rpm idle. $100. SOLD
'09 daytona radiator fan. $50 SOLD
more stuff to be added as time allows. thanks for looking.
SOLD:
