See my last build: http://www.triumph675.net/forum/showthread.php?t=207401
This new bike will be truly immaculate. Using all of the errors and issues I ran into with the previous bike, the new bike will be built to a much higher standard.
The donor bike is a new 2015 Street Triple
So let's get started...
- Custom aluminum license plate bracket
- OE Triumph Daytona 675R Ohlins TTX rear shock
- OE Triumph Daytona 675R driver seat
- OE Triumph 2016 Speed Triple raised tank emblems
- OE Triumph Speed Triple Throttle Tube
- OE Triumph Accessory Black Anodized Gear Actuator
- OE Triumph Accessory Black Anodized Adjustment Blocks
- OE Triumph Accessory Black Anodized Oil Cap
- OE Triumph Accessory Black Anodized Bobbins / Spools
- OE Triumph Accessory Black Anodized Rear Brake Reservoir
- OE Triumph Accessory Rear Hugger
- OE Triumph Accessory Front fork protectors
- Optronics Optiglo tail light
- Driven Racing Halo Gas Cap / Base (black/black)
- Driven Racing black SAI blockoff plates
- R&G kickstand shoe
- R&G radiator guard
- Evotech lower chain guard
- Superlite RS7 47T Rear Sprocket
- Racebolt UK black anodized sprocket nuts
- Temple Cycles pecan leather grips
- Brembo RCS 19 master cylinder
- Modified throttle cable bracket
- Modified sprocket cover to remove wiring "arms"
- Lightech Racing Black Anodized Rear Axle Nut
- LSL Black Anodized Sprocket Cover
- Sato Racing Shift Spindle Holder
- Lust Racing Jack Up Kit (adds 1" to rear height)
- Motodemic top gauge mount
- Front Fender Delete
- Bobbed Subframe
- Horn Delete
- Turn Signal Delete
- Fairing Delete
- Coolant Reservoir Delete
- Custom tail light panel / tail customization
- Smoothed wheel casting numbers/letters
- Smoothed lower fork mounts for front fender
- Handmade subframe belly panel
- Black powdercoated subframe
- Black powdercoated subframe belly panel
- Black powdercoated swingarm
- Black powdercoated frame
- Black powdercoated throttle cable bracket
- Black powdercoated triple tree
- Black powdercoated risers
- Black powdercoated gauge mount
- Black powdercoated lower yoke
- Black powdercoated kickstand
- Black powdercoated kickstand bracket
- Black powdercoated dogbone / drag link
- Black powdercoated license plate back
- Black powdercoated license plate bracket
- Black powdercoated gas tank bracket
- Black powdercoated handlebar
- BBS Gold painted tank emblems
- BBS Gold painted calipers
- BBS Gold painted wheels
- Estoril Blue painted tank
- Estoril Blue painted tank trims
- Gloss Black painted subframe inserts
- Gloss Black painted upper chain guard
- Smoothed / tinted tail light
- Smoothed / deburred frame
- Smoothed / deburred swingarm
- Smoothed tire sidewalls
- Black anodized grip trim rings
- Black anodized fork protector bezels
- Black anodized valve stems
- Black anodized spike valve stem caps
- Black anodized shift arm brace
- Black anodized sprocket cover
- Relicate Leather grips (hand-sewn)
- Relicate Leather-wrapped seat
- Evans waterless coolant conversion
- OEM ignition switch relocation
- Samco black silicone coolant hoses
- Samco coolant hose clamps
- Continental TKC80 tires (120/70 and 180/55)
- Custom bomber-style gauge face
- ProTaper Contour Mini Low Jet Black handlebar (narrowed 2", end ID opened to 15mm)
Stuff I need to save up for and buy:
- New Daytona 675R Front Forks
- New Brembo M4 100 Calipers
- Front rotors (brembo?)
- Mounting for rear of new seat
- Exhaust routing / design
- Oil pan bash guard - will get this covered in bedliner
- OE Triumph Accessory Frame Protectors - A9788013
- EK MVXZ black chain
With help from my friends at...
- Motodemic
- Classic Livery of Atlanta
- Origin Fabrication & Precision Welding
- Kickass Powdercoating
- Relicate Leather
- Cycle Gear
- Pandora's European Motorsports
- British Customs
- Bobbed Subframe
- Horn Delete
- Fairing Delete
- Motodemic
- Relicate Leather
- Cycle Gear
- British Customs
