Hi Guys,
I installed Daytona R Ohlins TTX Shock on my Street Triple RX. In addition I installed Kyle Racing linear suspension link. While the suspension low speed function is much improved the suspension fast speed is way too harsh. It seems as I'm hitting what I call "compression wall" every time I hit large bump on the road. What would be a good base set up for street riding using the Ohlins TTX?
BTW, I have my rider sag set up at 34MM.
Hi Guys,
That Link is not that common, it's a pretty expensive item for what it is. I'd guess less than 1% of the members here have installed one. Not saying that it isn't nice to have. :smile2:
OK, so what is your TTX set up? before I installed the link, i had my TTX set up as follow: Compression 13 clicks from fully close, Rebound 13 clicks from fully close.
Bike was steering well, holding line well, but was harsh on bumpy stuff. I've been told that the root cause was the progressive link and the nature of the TTX which load compression in very progressive way. To slow things up requires: 1) less progressive link 2) re-valve the TTX to modify its hi- speed compression load.
I have done #1 but have not done #2. Suspension is still harsh on high speed movement.
The problem with linear linkages on the street is just this, not as well suited for hitting large bumps and other things. The shock has to be adjusted to suit for sure.. where the progressive linkage the spring itself and the ratio aids in dealing with bumps..
The Ohlins was from EBAY retailer. The link from Kyle Racing directly.
Related Threads
Triumph 675 Forums
1.2M posts
39.9K members
Since 2005
