What did you do to your Street Triple today? - Page 152 - Triumph675.Net Forums
post #1511 of 6567 Old 04-29-12, 22:06
slevesque
Originally Posted by pokeyjoe View Post
Fixed my squeaking brakes and gave the bike a much-needed bath.
How did you fix your brakes? I have to solve my problem too.
slevesque is offline
post #1512 of 6567 Old 04-29-12, 23:04
pokeyjoe
pokeyjoe's Avatar
I sanded down the pads (60 grit sandpaper - just lay it on the ground and run the pads across it until the wear marks are gone) and took Scotch Brite pads to the discs (the stuff is like real fine sandpaper). Did the trick.
BTW, you pretty much remove the rear caliper the get the pads out. I discovered that the caliper pins (integrated into the mounting bolts) were pretty much dry. Have some brake grade grease handy.
If a British high school dropout can put it together, I can take it apart.
pokeyjoe is offline
post #1513 of 6567 Old 04-30-12, 18:02
Roadstergal
Roadstergal's Avatar
Originally Posted by ANZAC View Post
That photo looks familiar like in San Mateo or Sunnyvale? How do you like your screen?
South San Francisco. I haven't had a chance to ride with the screen yet - I bicycle to work. I'm racing supermoto at the West Coast Moto Jam next weekend, so the Striple is going to be in the garage until the weekend after that, when we've planned a fun ride.
Roadstergal is offline
post #1514 of 6567 Old 04-30-12, 18:34
DocWalt
DocWalt's Avatar
My rear brake is a little squeaky as well. Thanks for the suggestion on how to stop it, even though it's not exactly a huge problem. Definitely doesn't ruin the ownership experience
DocWalt is offline
post #1515 of 6567 Old 05-01-12, 10:54
Racer009
Racer009's Avatar
I broke the thousand mile marker and then the Check Engine light came on.
Racer009 is offline
post #1516 of 6567 Old 05-01-12, 18:08
OKStriple
OKStriple's Avatar
Pulled off the rearsets, headlight buckets and kickstand and shipped them off to NJCustoms for powder coating.
2009 Matte Graphite Street Triple R. Arrow Slip on's, TecSpecs, GB Racing Protection bundle, CRG Lane Split Mirrors, on Michelin Pilot Road III
7643 posts behind MacBandit and getting further behind each day
OKStriple is offline
post #1517 of 6567 Old 05-01-12, 21:10
spike_africa
spike_africa's Avatar
I hit 13k miles today! Better get my manual timing chain adjuster and check my valves now.
2009 Black Street Triple- Mine
2009 White 696 Ducati Monster- Hers
spike_africa is offline
post #1518 of 6567 Old 05-01-12, 23:01
Talus
Talus's Avatar
You doing the work yourself?
Talus is offline
post #1519 of 6567 Old 05-02-12, 11:41
builtgypsy
builtgypsy's Avatar
I played around with number today on a short little ride. I've discovered on fairly level ground, around 4000-4200 RPM, going anywhere from 48-60 MPH in 6th gear, I'm getting 47-48 MPG. Down slope, it jumped up to 55 with my hand off the throttle until I hit level ground again. Up slope, it dropped to 43-45.
That's a whole lot more than I've been getting puttering around in 4th gear around town.
builtgypsy is offline
post #1520 of 6567 Old 05-05-12, 14:33 Thread Starter
Tronix
Tronix's Avatar
had an awesome group ride today...even though it poured out all of us :(
Bike: 2012 Triumph Street Triple R - My youtube channel with my videos
Car: 2012 MazdaSpeed3 JBR TIP SRI | Damond OCC | COBB AP | Stage 1 S-OTS 93
Tronix is offline
