Adventure in detail: The "baby steps" build - Page 4 - Triumph675.Net Forums
675 Photos Pictures and more pictures!!!
post #31 of 179 Old 04-15-16, 08:04 Thread Starter
tacomahogany
tacomahogany's Avatar
Forgot the 1/2" breaker bar so I couldn't get the triple tree nor rear axle out just yet.
MANY NEW OEM PARTS FOR SALE
2009 Matte Graphite Street Triple - Totaled
2013 Spruce Mica Metallic / Spanish Gold Street Tracker Custom - Sold
2015 Estoril Blue / BBS Gold Street Tracker Custom - Build Underway
tacomahogany is offline
post #32 of 179 Old 04-15-16, 08:38 Thread Starter
tacomahogany
Finally some actual modification!
Chopped the tail frame:
post #33 of 179 Old 04-15-16, 08:59
Hooligaz675
Hooligaz675's Avatar
Originally Posted by tacomahogany View Post
Located and ordered some 2016 Speed Triple tank emblems from my dealer. They had to get them from the UK.
They're about two weeks out and will be painted gloss black.
I've been after the '16 Speed Triple /Thruxton R tank decals for months now. Where did you get them from in the UK if you don't mind telling me
This is going to be a beautiful custom ST 675 RS for sure
- Do Not OpenNo User Serviceable Parts Inside ! -
Street Triple 2015 to custom RX with Daytona 675R front-end (aka Hooligaz RS Build)
Hooligaz675 is offline
post #34 of 179 Old 04-15-16, 09:29 Thread Starter
tacomahogany
My dealer got them for me, actually.
post #35 of 179 Old 04-18-16, 18:16
frank20
frank20's Avatar
Sure is. Like 6 small philips screws on the back, then use a small flathead under one edge of the trim. Be careful when pulling it off since there's foam double-sided tape holding the trim on, but no screws or clips. Then you have to pop out the two rubber button covers.
Thank you! On a separate note, did you rebuild your calipers after having them powdercoated. I found new seal kits for the front calipers but I cannot seem to find anything available for the rear brembo caliper?
2014 Triumph Street Triple
frank20 is offline
post #36 of 179 Old 04-18-16, 18:41 Thread Starter
tacomahogany
Since the bike is literally new, I pull the seals and pistons first, then have them powdered, then toss everything back in. Works just fine.
With this said, this time around the wheels and brakes will be painted for a better finish. Powder looks nice at ten feet, but the coating on these wheels was so awful for my powdercoater, it had issues that irked me.
post #37 of 179 Old 04-18-16, 21:51
frank20
frank20's Avatar
Thanks. My bike had 1000 miles on it before I began tearing it down over the winter. I'm going with new seals on the fronts since they are available but for the rears it looks like I'll try to reuse the originals. Any recommendations on taking out the Pistons and seals? I have them calipers completely apart with the exception of the Pistons and seals.
Thanks
frank20 is offline
post #38 of 179 Old 04-19-16, 08:24 Thread Starter
tacomahogany
Thanks
It's super easy. Just pull the seals with a small pick, then blast the pistons out with compressed air in the fluid inlet. have a piece of thin wood on hand so they both come out simultaneously.
post #39 of 179 Old 04-19-16, 08:26 Thread Starter
tacomahogany
Got that Autoglym / Samco hose cleaning stuff from the UK. It works amazing even on the OEM rubber hoses. Left is clean, right is how it came. The black/white shows it best.
Chopped down the bracket that holds the throttle cable and right mini fairing, so now it is just for the throttle cable. I'll probably sandblast it here in a second and then send it to be powdercoated.
post #40 of 179 Old 04-19-16, 08:41 Thread Starter
tacomahogany
Sandblasted and deburred:
The Following User Says Thank You to tacomahogany For This Useful Post:
posnikb (04-22-16)
