Does any one know how to discount the exup value on a 2012 daytona I have the arrow can fitted with the arrow ecu map on the bike.
Is it just a case of getting under my bike and removing the cables from the value? Thanks matt |
You got two choices simply disable it by using tune ecu program or disable it and remove it all together I did both its not that hard at all
Thank you I don't really want to play with the ecu
When you say move it is that just discounting the cables at both ends and do you have to wire at open as heard it default is closed? |
#4 | |
You will get the job done
You can tell what position the valve is in by looking at the rod coming out that the cam/cables are attached to. The flats on the rod are in the same direction as the valve itself. Make sure the flats are horizontal and not vertical.
Realize you will get a check engine light if you remove the cables and motor and don't turn it off using TuneECU. |
#6 | |
In thinking by doing this the ecu wouldn't,t know I've moved the cable from the value I don,t have a laptop I'm on here via an iPad |
#7 | |
tune ecu is very easy to use.
I still get those 'oh shit' moments.... The day I don't, is the day I stop riding. '11 675R Werkes Slip On Pipe + STD Fender Elim + Intergrated Tailight - ZG Double Bubble DS - Dual HID Headlights and Angel Eyes with Coloured Headlight Housing - Red Seat Cowl - LED Strip Indicators - 1050 Throttle Tube - Attack Reasrsets (Red Pegs) - Powdercoated wheels and Sidestand - GB protection Kit - CRG Levers folding - Saddlemen CF Track Seat - Watsens |
#8 |
+1 if you're going to disconnect it, you need to disable it. Spend $10 or whatever it is for the cable, borrow a laptop, and get it done. It will be beneficial.
I'm not driving fast - I'm flying low ![]() "I actually just have my throttle cable pulled so its wide open even when i start the bike. balls to the wall is how i live, screw stoplights and slow people." - TwoWheeledWonder |
#9 |
It is very simple to do. Where are you located? I am sure there is someone on the forum local to you that could help you out with the cable and laptop.
1993 Mitsubishi 3000GT VR-4 2007 D675
