What spring do I pick? - Triumph675.Net Forums
Old 12-13-12, 04:25   #1
nixthewiz
Default What spring do I pick?
I'm looking to swap out my stock spring for something that suits my weight. I weight 175lbs without gear. Should I get the 550lbs or 600lbs spring? What is the spring dimension (is it 7 x 2.25)? I do mainly street riding on the bike. Nothing really aggressive.
Also does switching the shock out affect how the bike handle 2-up riding?
Old 12-13-12, 08:01   #2
sittingturbo
sittingturbo's Avatar
I have a spring you might be interested in, it is a Hyperco 7", I am 160 w/ gear and only ride track (advanced) so for your at 175 with only street riding, this might work. Since you want a little more plush of a spring. Not to mention we are talking about a 15-20 pound difference in actual weight, where as springs only come in like 50 pound increments.
Off the top of my head I am going to say it is 550... But there is a possibility it's 500. I need to pull it off the bike today to check, I am swapping to my new (refurbished) Elka which I just got from Steve at Fluidology, it uses a 6" spring so I will not need the 7".
Old 12-13-12, 09:47   #3
Neanderthal
Neanderthal's Avatar
Originally Posted by dcom3g.net View Post
Mình chuyên bán dcom 3g viettel. B?n có c?n thì liên h? mình :D K?t n?i internet không dây m?i lúc m?i noi, r?t lÃ* ti?n d?ng. Có r?t nhi?u d? b?n ch?n, b?n vÃ*o http://dcom3g.net xem nhé
Here's to you dcom3g.net!
Old 12-13-12, 11:18   #4
absowoot
absowoot's Avatar
I think you want to go with the 600lbs spring, especially if you're going to do 2-up.
Old 12-13-12, 14:39   #5
jason68278
jason68278's Avatar
what size spring comes on the bike?
"Just dreaming about doing wheelies"
Old 12-13-12, 14:44   #6
nixthewiz
For the Daytona the stock spring is 7.5" x 2.25". The problem is the spring is for carrying a rider weighting 300lbs. Good for two up. Not good for other uses.
Old 12-13-12, 14:44   #7
Torchsport
Torchsport's Avatar
Location: 90 miles from Brainerd International Raceway, Minnesota
***Current bikes***
'12 Triumph Daytona 675R
'06 Yamaha FZ1 (Sport-tour)
'05 Honda CRF50-88cc (Mini SM race bike)
'04 Yamaha YZF-R6 (Track bike)
'03 Honda GL1800 (Lazy-boy)
'02 Honda XR50 (Pit bike)
'01 Suzuki DRZ400S (Dual sport)
Old 12-13-12, 14:46   #8
sittingturbo
I think the stock spring is like 7.5 but all aftermarket springs are 7". You use the preload to adjust the ride height... The same as the forks, stock springs are shorter then lets say Race Tech Springs. So you have to cut the preload spacer in the forks... For some reason, no one makes direct replacements, probably for a wider array of uses...
Old 12-13-12, 17:23   #9
Logans08Daytona675
Logans08Daytona675's Avatar
This needs to be moved to suspension and your question has already been asked and probably answered. I very simple search would get you there. check under mods and then suspension
Old 12-13-12, 18:17   #10
nixthewiz
I searched but everything that came up was spring recommendations for someone who's 150lbs or 190lbs.
