Problem Starting Street Triple - Triumph675.Net Forums
Old 12-13-12, 03:39   #1
eddieikea
Default Problem Starting Street Triple
Hi all,
Ive recently bought a 2008 Street Triple, amazing condition in routette green.
Trouble is that it hasnt been riden too regularly, only 6,000kms over the last 5 years.
It started perfectly when i first bought it, now 3 weeks later, nothing.
Power comes on, lights and tacho checks per normal, but when pressing the start button, it clicks and the clocks go off, then immediatly back on again, just like i turned off the key. Checked all the basics, kill switch, stand, battery is showing 11.6v when iginition is of and the same when on.
Any ideas?
Old 12-13-12, 03:51   #2
I'd put the battery on a tender. These bikes can be kind of picky about voltage.
2010 TornadoRed D675
Old 12-13-12, 08:37   #3
ANZAC
ANZAC's Avatar
Take the bike in to Triumph and get your regulator rectifier replaced. Do a search on this for more details.
Welcome aboard
He has Risen
Old 12-13-12, 08:39   #4
2BRacing
Due to extended periods of standing and not being charged, your battery has probably sulphated to such an extent that it will not hold a charge, even after being on a tender. A good battery voltage reading should be around 12.7 with ignition switched off. Have the battery load-tested.
Old 12-13-12, 16:01   #5
eddieikea
thanks guys, will give all the above a shot/
Cheers
Eddieikea
Old 12-13-12, 17:09   #6
Spearo
Spearo's Avatar
Your battery is toast. Replace it with a Shorai battery. No more headache with those and their super slow discharge rate.
Old 12-14-12, 07:57   #7
Welcome aboard
All of the above.
Your bike almost certainly qualifies for the R/R recall. Get it done asap. If it has failed it's probably taken the battery out. In any case it's probably past it. Even if it shows enough volts it may not have enough amps (?) to turn the motor. I had a battery like that.
When you get the new battery put it on charge for a CONTINUOUS 48 hours, even though the green light on the charger will come on long before that. This will ensure you get the most life out of the battery.
Last year I bought a 2006 Daytona with 800 miles on the clock. So yours is well used compared to mine!
Old 01-02-13, 22:12   #8
whitfield720
whitfield720's Avatar
11.6v is too low. These bikes are EXTREMELY sensitive to voltage. It shouldnt be too far gone but as others have stated above, I would keep it on a tender whenever not riding. Definitely a battery issue here.
Sent from my DROIDX using Motorcycle.com Free App
Old 01-03-13, 06:52   #9
Any update? What's the latest?
Old 01-03-13, 07:36   #10
Meh why waste the money, I still have my OEM battery only time I put it on a tender is in the winter when temps get real low and it is not being started regularly. A 30 dollar tender is a lot cheaper than a new battery and as long as you keep the battery with a good charge and keep it at room temp that thing will last a few years like mine has.
Tags
#ignition, #power, #starting
