What did you do to your Street Triple today? - Page 299 - Triumph675.Net Forums
post #2981 of 6564 Old 12-11-12, 04:00
Nice work ZR
2010 TornadoRed D675 Trackbike
TwoWheeledWonder is offline
post #2982 of 6564 Old 12-11-12, 04:06
ZrexRich
ZrexRich's Avatar
Thanks!
ZrexRich is offline
post #2983 of 6564 Old 12-11-12, 15:20
e rock
e rock's Avatar
ZrexRich, what map are you running w/those DanMotos?
e rock is offline
post #2984 of 6564 Old 12-12-12, 01:43
ZrexRich
ZrexRich's Avatar
I'm still running the stock map. I'm also using two db killers in each muffler as they were still to loud for my liking(I work swing shift and don't get home untill after 10PM). I will probably try a different map when I install some Daytona cams at the 12K service.
ZrexRich is offline
post #2985 of 6564 Old 12-12-12, 06:48
Orangeman
Orangeman's Avatar
Probably ??????? try MUST..... and it will require a custom map....
.. My Bike.. ...has a new owner :(
Orangeman is offline
post #2986 of 6564 Old 12-12-12, 17:13
Johnnystriple
Johnnystriple's Avatar
Great write up. I just checked to make sure my tender was still working.
Johnnystriple is offline
post #2987 of 6564 Old 12-17-12, 18:48
f4nm4n
f4nm4n's Avatar
Cleaned out an area of my barn to store the bike for the winter. Got her mostly sorted but will have some work to do once the christmas gifts roll in. First winter with my first bike... added fuel stabilizer then put it up on stands. Removed the seat and put the battery on a tender. cleaned and lubed the chain. Anything else i missed? Canadian winter btw.
f4nm4n is offline
post #2988 of 6564 Old 12-17-12, 19:50
Did you change the oil? You don't want to let used oil sit in it for too long. It's nasty stuff.
2012 Street Triple (Trinity) - Phantom Black
2014 Audi A5 - Scuba Blue
Trinity's Build Thread
Nastybutler is offline
post #2989 of 6564 Old 12-17-12, 20:53
GuiltySparc
GuiltySparc's Avatar
Might also want to cover up openings like the exhaust if you're out in mouse country.
2010 Ninja 250R
2012 Street Triple R
2006 Daytona
GuiltySparc is offline
post #2990 of 6564 Old 12-17-12, 20:53
f4nm4n
f4nm4n's Avatar
Didnt change the oil. Was going to change it in spring before next season, guess its better to do it now and let it sit? didnt know if oil degraded over time so would be a waste changing it before storing. Thanks for the tip :) something to get done this weekend.
f4nm4n is offline
